Detroit Tuned :: Tensioner Stop
Old Jan 12, 2007 | 07:50 PM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
The Detroit Tuned Tensioner Stop is here. After trying all the products on the market, we decided to make one that worked better for less. Many of the stops on the market do not allow you to fully de-tension the belt tensioner for service. Our flexible but strong cable allows the full movement needed in the tensioner. Should your belt brake, our stop will keep everything together. The large flat ends allow extra protection for the shock’s rubber bushings. The ends keep the bushings protected and in place. No more looking at your tensioner only to find the bushings are ripped and working their way out.
Each uses a cable rated for 340 lbs, crimped, and soldered for good measure. The first units were tested on a car with a 4% crank pulley. We took off the belt and let it go to check for clearance. With the tensioner fully extended, you will have about 1/8 of an inch before the tab that runs through the spring hits the spring limiter and breaks. If you running a crank pulley on your MINI, this is a must add item. Don’t let a broken belt turn into a $400 dollar fix.
All of this for a very low price of $20.00!!!
A Full Shot:
Another Shot:
What it looks like on the car:
What the stock stop will look like after your belt brakes with the DT TS:
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Teh
Aug 22, 2022 04:37 AM
MoganDavid
Mar 14, 2016 10:44 AM
12magnum
Aug 31, 2015 08:22 PM
Aug 7, 2015 09:51 AM
