New ECS F56+ Metal Oil Cap! New Ziza F60 LEDs
Old Jan 30, 2026 | 01:20 PM
ECS Tuning
Designed to fix a known weak point for the MINI B3X and B4X engines, this billet aluminum oil filter housing cap is a direct replacement for the factory plastic cap. The OEM piece is infamous for cracks, stripped threads, and rounded hex heads—often failing during routine oil changes and turning basic maintenance into a frustrating, time-consuming repair.
Our precision-machined billet aluminum upgrade eliminates those issues, delivering strength, durability, and consistent fitment you can rely on. An integrated drain plug allows you to drain the filter housing cleanly before removal, reducing spills and mess for a faster, cleaner oil service. It’s a simple, smart upgrade that improves serviceability, reliability, and underhood appearance—exactly the way it should have been from the factory.
Replaces OEM MINI part number 11428575907. MINI 2014-2019
Install Tip** When installing aftermarket or factory filter you will need to replace or install a new O-ring from the plastic 10NM Drain plug on the cap. Our design on the 10NM drain plug only needs the smaller O-ring from that oil change kit.
**When installing aftermarket or factory oil filters you will have to align the filter on the tube inside the oil filter housing then align and tighten down the cap. This forces the plastic tabs on the top of the filter to snap in the tight metal tabs on the inside of the cap.
We even have it paired with our Bremmen Parts Oil filter housing upgrade for the Ultimate Combo!
Fitment:
Fits:: F54-F57 MINI Cooper /S/JCW 1.5L and 2.0L 2014-2019
And Free shipping!
"Click HERE for the New ECS Billet Aluminum Oil Filter Cap
__________________________________________________ _________________
ECS Tuning
These headlights are designed to resemble the later Gen 3 F60 LCI+ MINI OEM LED Projector headlights, but are for the F60 MINI Cooper Models. Featuring high impact plastic lenses with black housing, these lights use an LED DRL and black exterior LCI+ design.
*Designed for MINIs without factory LED headlights.
Plug-and-play.
**factory halogen headlights do not have headlight washers**.
Features:
  • Manual adjustable leveling on back
  • E-code cutoffs on the projector for left hand drive models; motorized for Hi/Low beam with Bi-LED setup
  • Black matte housing design with chrome and no MINI logo
  • Plug and play
  • Turn signal integration and DRL rings.
Fitment:
Fits:: F60 MINI Countryman ALL4/S/S ALL4 / JCW 1.5L and 2.0L 2017-2020
And Free shipping!
"Click HERE for the New Ziza F60 LED Headlights
"Click HERE for the All New Ziza LED Headlights
Feb 13, 2018 01:04 PM
