:: ECS Tuning :: Supercharged FORGE : We NOW carry MILLTEK Exhaust .... UK Finest
Old May 8, 2015 | 02:56 PM
MINI R52 R53 S/JCW Forge Products
Forge Motorsport has developed a reputation for premium performance upgrades that address oftentimes overlooked areas of your vehicle.
ECS offers an extensive range of some of the most impressive Forge products for your MINI R52 R53 S/JCW.
The Alloy Power Assisted Steering Fluid Tank is a stunning piece, dressing up your engine bay while increasing the durability and longevity of the unit.
The stock rubber hoses on the MINI can often split, swell, and break over time. Forge offers chemical and corrosion-resistant Silicone Intake Hoses, available in Red, Black and Blue.
Forge Ahead
Fits:
R53 MINI Cooper S / JCW (2002-2006)
R52 MINI Cooper Convertible S / JCW (2005-2008)
Click HERE for FORGE
MINI Gen2 Turbo Oil Line Kit
Turbochargers operate at speeds at over over 100,000 rpms. The lubrication requirements for this type of system are understandably highly specific and critical to observe carefully.
The MINI Gen2 feed and return oil lines have a tendency to weaken due primarily to heat exposure, making oil delivery precarious, compromising overall engine health.
The Genuine MINI Turbo Oil Line Kit includes both new return and feed oil lines, as well as a heat resistant plate that installs on the new oil pipe for protection from further damage.
Each kit also includes all installation hardware.
Lubricious
Fits:
R56 MINI Cooper S/JCW (2007-2013)
R55 MINI Clubman S/JCW (2008-2014)
R57 MINI Cooper Convertible S/JCW (2009+)
R58 MINI Coupe' S/JCW (2012+)
R59 MINI Roadster S/JCW (2012+)
Click HERE For Oil line kit
Mini R55 R56 R57 R58 R59 N16 Valve Cover
A damaged valve cover can cause oil leaks, vacuum leaks, driveability problems, and a check engine light. Additionally, cracks and warping can result in a significant vacuum leak and result in very poor performance.
The MINI N16 valve cover is prone to damage over time. For this part, an aftermarket replacement is not an option - ECS supplies Genuine OEM MINI Valve Cover replacements for your car.
Included in the kit are all necessary parts for a professional-level installation - a new valve cover gasket, valve cover seals for the spark plug tubes, and Oil cap & seal.
Got You Covered
Fits: N16 Engine
R56 MINI Cooper (2011-2013)
R55 MINI Clubman (2011-2014)
R57 MINI Cooper Convertible (2011+)
R58 MINI Coupe'(2012+)
R59 MINI Roadster (2012+)
Click HERE For Valve covers
MINI Gen2 JCW Timing Chain Kits
Accurate and reliable engine timing requires the cooperation of several critical components. Wear is typically systemic - meaning as one component wears significantly, other parts begin to lose functionality and fail, beginning a cumulative effect of system failure.
To avoid the catastrophic consequences inherent in timing system failure, invest in an ECS-assembled Timing Chain Kit.
The ECS kit includes carefully selected components for a thorough refresh - a new timing chain and chain tensioner, timing chain guide rails, inlet cam bolt, outlet cam bolt, and crankshaft gear.
Right on Time
Fits: N18 Engine
R56 MINI Cooper JCW (2013)
R55 MINI Clubman JCW (2013-2014)
R57 MINI Cooper Convertible JCW (2013+)
R58 MINI Coupe' JCW (2013+)
R59 MINI Roadster JCW (2013+)
Click HERE For Timing Kit
MINI R53 Cooper S / JCW Milltek Performance Exhaust Systems
Milltek's MINI offerings exude the engineering rigor and attention to detail that come from experience developing prototype exhaust designs in highly demanding circumstances for race teams throughout the world.
Every single Milltek product offering is designed and manufactured in-house in the UK. Milltek tests each system on their own dynometer through many miles of subjective analysis, fine tuning each component of each system for its specific application.
Milltek's collaboration with ECS Tuning allows unprecedented access to these exceptional performance exhaust systems.
Tested - Proven
Fits:
Click HERE For Milltek
MINI R52 Cooper S/ JCW Milltek Performance Exhaust Systems
Tested - Proven
Fits:
Jan 4, 2019 12:51 PM
Aug 12, 2015 01:24 PM
Aug 11, 2015 11:58 AM
Aug 10, 2015 02:03 PM
Aug 10, 2015 01:59 PM
