Brand New Products From ALTA Performance !!
Old Feb 26, 2008 | 11:35 AM
ALTADESIGN's Avatar
ALTADESIGN
Manufacturer
R56 Gauge Pods
Add the vital gauges MINI forgot with the ALTA Performance™ Gauge Pod. Crafted specifically to the contours of the R56 Tachometer, the pod provides a sturdy and convenient place for either a 52mm or 60mm Gauge. ALTA has expertly crafted the pod so the tilt function of your steering column is maintained without binding or damaging the dashboard. Simple adjustment of the steering column will allow drivers of all sizes to enjoy a clear view of their new high performance gauges.
The ALTA Performance™ R56 style gauge pod simply attaches to the back of the tachometer utilizing existing mounting points. Your tachometer, dashboard, and steering column are not damaged in anyway! This is completely reversible at any time! Up to THREE can be mounted on the Tachometer at any time. One on either side and one on top.
Available as a pod only or in kits featuring Prosport gauges. Prices range from $79.99 to $189.99 depending on gauge choice.
Browse our Gauge Pod Options HERE
NAM Discussion thread <-----Click Here
__________________________________________________ ______________
Prosport Gauges
Included in in ALTA Performance gauge kits
Available in either 52mm or 60mm sizes with Amber/White faces, Prosport gauges are all Stepper Motor Driven and feature a 270° LED Display. All Prosport Premium Series gauges perform a dramatic opening ceremony with a full pointer sweep each time the vehicle is turned on AND off.
Track tested and race proven these gauges use precision electric senders to keep hazardous fluids out of the passenger compartment. These are very easy to use, all programming is done from the front push button!
Prosport gauges have a warning feature to either beep or change color (or both) once the gauge reaches your pre-set limit and feature peak recall ability.When using multiple gauges, just wire up the first gauge for power and daisy chain the power to each gauge as needed!
R56 ALTA Performance MAP / Boost Adaptor
Included in the ALTA Performance Gauge pod & boost gauge Kit.....
The ALTA Performance MAP / Boost adapter allows R56 owners to easily pull a vacuum line (needed for the boost gauge) without having to drill and tap the manifold.
ALTA Performance R56 Stealth Front Mount Intercooler
NOW IN NEW STEALTH BLACK COATING! The ultimate sleeper look!
MSRP $839.99
Add roughly 20 WHP in about 2 hours of work! So far, the ALTA Front Mounted Intercooler is near the top of the list for best bang for the buck part availible for the R56.
Read all about ALTA Front mount intercoolers HERE
AWOL
Mar 28, 2016 10:51 AM
MINI VINI
Oct 13, 2015 08:57 AM
stierzy34
Sep 15, 2015 04:40 PM
bjcarter2
Aug 31, 2015 04:03 PM
blackie
Aug 25, 2015 09:08 PM
