New Products from ProMini/BMPDesign
Old Jun 26, 2003 | 08:56 PM
Casey's Avatar
Casey
H&R Front and Rear Sway Bars
H&R Sway Bars are the perfect compliment to H&R spring and coil over kits. Designed to reduce body roll, increase lateral stiffness and improve handling as a whole, H&R Sway Bars are made using a proprietary alloy that is both stronger and more resilient than competitive sway bars. All Sway Bar kits have precision forged ends and include bushings made from an exclusive urethane/Teflon composite that eliminates squeaks, and doesn't require lubrication, Ever. That means no mess, no maintenance, just bolt in H&R Sway Bars and go! The Front is 27mm and the Rear comes in your choice of 18mm or 19mm and is 2 way adjustable.
K-MAC Adjustable Camber, Caster, and Toe Mounts
A unique new item enabling you to adjust your camber, caster, and toe angles by merely loosening the upper strut tower mounting nuts. All this is done from within the engine compartment without raising the vechicle. This is an excellent item for increasing camber for competition applications, or for decreasing the camber for improved tire wear. The vernier design permits the smallest incremental adjustment with a total range of up to 2.0 degrees. So simple to adjust that you can do track side adjustments in just minutes. The rear adjusters are simple bushing replacements. Once installed they require only rotation for easy camber and toe adjustment. Fits both the Cooper and Cooper S. These come in both Race and Street versions.
For these and all other products check out ProMini and make sure to sign up for the ProMini mailing list and be the first to know about new products and great discounts.
OutMotoring
Mar 3, 2017 06:29 AM
minimofo
Dec 26, 2015 12:03 PM
flpat73
Nov 2, 2015 06:38 PM
simo711
Oct 1, 2015 05:36 AM
Emnotek
Sep 29, 2015 07:37 AM
