The ORIGINAL LIGHT BAR...back in stock...Palo Uber Mini.com
Old Jun 26, 2007 | 09:08 PM
Carol@PaloUberMini.com's Avatar
We finally recieved our order from London and are back in stock on our PaloUber "Light Bar"........
We still have the only diving lamp and/or fog lamp mounting system which is COMPLETELY CONCEALED inside your lower dam. Each bar is constructed from a one inch stainles steel bar, laser cut. robotic welded and powder-coated for years of worry free enjoyment. The Light Bar will increase your visibility through any climactic condition you may encounter.
Each bar mounts directly to existing bolts on your frame, and no drilling steel to level the bar is required. No exposed tabs to come loose. The bar is perfectly positioned and perfectly level once mounted to your existing frame bolts.
The system is ignition activated, preventing accidental illumination when the mini is turned off. You can run each set of two lamps independently due to our wiring harness. Run your two most outer lamps, or your inside two lamps, or all four at the same time. Our wiring harness is completely moisture resistant and fully bound. All end connectors are already attached, all fuses and relays are already in place.
A texturized powder coated faceplate is located under your toggle row, out of the way, but easily accesible. Two switches are of course also included, and illuminate if the lamps are activated.
The Light Bar is definitely a visual trade mark item of the Palo Uber Mini's, and have been installed world-wide. This Uber designed product will not only provide significant visual enhancement to your mini, but provide dynamic visual capability regardless of the weather you may encounter.
To see extensive photos; go to www.paloubermini.com and go to the "gallery" page. Photos also on the online store catalogue.
NAM members save nearly $100.00......................................
TO ORDER;
go to www.paloubermini.com and then go to the online store catalogue and scroll to find NAM KIT # 3 L and place your order.
NAM orders always recieve priority in shipping.
If you prefer, ring us at our facility in California, so we can fill your order by tele, or answer any questions you may have......949-725-7983
ryGuyMCS
Oct 20, 2015 02:24 PM
blackie
Sep 2, 2015 09:16 PM
Powershift
Aug 16, 2015 05:14 PM
Dashdog
Aug 10, 2015 06:17 AM
FatherG
Aug 4, 2015 03:44 PM
