17x7.5 - 43.5mm offset?
Old Mar 27, 2007 | 07:57 AM
Sanderskog's Avatar
Sanderskog
A guy at my work is selling a rims in this side. They're off of an early Integra.
Any insight to if they will fit? I've been searching and can't find a clear answer.
Thanks!
Todd
Old Mar 27, 2007 | 10:24 AM
UKCoopeR's Avatar
UKCoopeR
i don't know if that offset will fit, but the MINI has a 4x100 bolt pattern, does that match these rims ?
Old Mar 27, 2007 | 10:43 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Thanks!
Todd
A quick search shows that it is possible it would fit.
Just confirm that the bolt pattern is 4x100.
17x7.5 is fine- should clear the brake calipers unless you have upgraded to a big brake kit.
+43mm offset is OK with stock or lowered suspension on the MINI
Hubbore hopefully is at least 56.1mm and if it is larger then you might need centering rings.
I would not expect them to be very lightweight. I think you mean the rims are aftermarket rims and currently on an Integra (Type R?).
Also inspect them- inner and outer edges for any damage.
Are there any tires- some will be too low on load rating for the MINI and some will be the wrong outer tire diameter- too small or too large.
Would it be rims only- if so you can do a test fitting- be sure to check both front and rear for rubbing.
Old Mar 29, 2007 | 12:28 PM
kmickey's Avatar
kmickey
I'm using Volkes ce28 that are 17x7.5" with a 43 offset.
Tires are 215/40/17, BBK, and car is lower than stock. No problems at all.
Thanks!
Todd
bahman
Aug 6, 2016 07:19 AM
Chibi2
May 19, 2016 03:46 PM
Amberleigh MacIntyre
R55 :: Clubman Talk (2008+)
Nov 11, 2015 11:59 AM
vbmike
Oct 15, 2015 04:32 AM
