Brembo's and R-90's
Old Dec 19, 2006 | 02:36 PM
tjmarrone's Avatar
tjmarrone
Brembo's and R-90's
Anyone running a Brembo BBK with R-90 rims? Are spacers required and if so how thick? Lastly, where would you recommend to buy spacers and of what material?
Thanks, T. J.
Old Dec 21, 2006 | 07:27 PM
JCW Driver's Avatar
JCW Driver
I doubt it will fit, but I could not say for sure. My S-lites took 20 mil spacers.
H&R makes a good spacer. Trax is the model
http://www.hrsprings.com/site/index.html
TRAK+ Wheel Spacers:
Kit DR 5mm 1024562 $ 49.95
Kit DR 15mm 3024562 $ 95.00
Kit DR 20mm 4024562 $ 99.95
Kit DRA 25mm 5024562 $ 149.95
Kit DRA 30mm 6024562 $ 179.95 Kit
Old Dec 21, 2006 | 09:40 PM
dkstone's Avatar
dkstone
Thanks, T. J.
Will require 10mm per wheel, 10mm are hard to come by since most only carry 5mm, 15mm, 20mm and so on, so buy 2 10mm spacer kits from Turner each kit has 2 5mm spacers from H&R, that is what I have been using for the past 3 years
Old Dec 21, 2006 | 10:16 PM
JCW Driver's Avatar
JCW Driver
If you can get away with 8mm, there is option. Mini-Madness (George) sells 8mm, in addition to the 15 and 5. You should have a 2-3mm gap between the wheel spoke and the caliper, at a minimum. Less than that can cause problems as the wheels deflect under load.
http://www.mini-madness.com/index.as...ROD&ProdID=132
RobbyD
Jan 29, 2019 01:22 PM
Tires, Wheels & Brakes
Oct 1, 2015 02:50 PM
