Brake ducts revisited
Old Jun 28, 2006 | 07:38 AM
mtrspt5's Avatar
mtrspt5
There hasn't been much discussion lately on this subject and now after four sessions on the track with all of my mods, the brakes are the weak point as I experience intermittent fade and fluid boiling (using Motul). I know I can build my own brake ducts, but was wondering if anyone has run into a prebuilt solution.
Old Jun 28, 2006 | 08:04 AM
SteveS's Avatar
SteveS
search forum for brake ducts.
You'll find this post, among others.
https://www.northamericanmotoring.co...ht=brake+ducts
It looks like this is best/cheapest mod for tracking.
I haven't tracked mine though.
Old Jun 28, 2006 | 08:09 AM
mtrspt5's Avatar
mtrspt5
I did that already. Was wondering if anyone has run across anything new.
Old Jul 3, 2006 | 03:00 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Hey, Guys-
Cheap brake ducts: Get 2 ea. tops from large liquid detergent bottles (pick your fav color) and about 1 ft. of 2" flexible tubing. Remove the front fender liners (ez job). Remove your fog lamps or the block off plates if no fogs. Re-position the inner fender liners so you can mark where the center of the fog lamp opening would be on the liner. Using a 2" hole saw (like carpenters use for door locks), cut a hole in each fender liner. Cut the tops out of the detergent bottle caps. Insert one in each fog lamp hole. Insert 2" flex tubing so that it goes thru the hole in the liner and over the detergent cap. I cut my tubing off flush w/the liner, drilled two small holes on either side of the 2" hole and hog-ringed the metal wire in the hose to the fender liner. Have already tested at CMP and VIR w/no heat-related brake problems.
Old Jul 6, 2006 | 03:55 PM
MarkC's Avatar
MarkC
Mtrspt5
Do you have braided brake lines? They should help with brake fade.
I do not have ducts on my Spec MINI (road racing in Arizona heat) and have never had a problem with fade. I do have the StopTech BBK on fronts.
Hope this helps
Tires, Wheels & Brakes
Sep 10, 2015 12:27 PM
Sep 10, 2015 10:52 AM
Tinklespout
16
Sep 6, 2015 11:39 AM
Sep 4, 2015 09:23 AM
PelicanParts.com
Sep 3, 2015 03:22 PM
