Proper tire size for an 18X8 wheel
Old Jun 10, 2006 | 09:03 AM
idoc's Avatar
idoc
Looking for some expertise, I ordered an 18x8 HRE Wheel and was told to put a 225-35-18 on it, but someone else recommened a 215-13-18. Can someone shed some light on what the difference would be and which would be better?
Old Jun 10, 2006 | 09:28 AM
J0kER's Avatar
J0kER
i assume ur sayin' 215 35 18 fer tha second choice^ if ur lookin' to do an aggressive drop then ur best choice would be a 215 tomake sure that ur tyre does not get in tha way,u will have a bit af a stretch 'look' tho. a 225 would be better if urlookin' fer that slight stretch 'look' w/more rubber to protect ur kick *** HRE's.....go w/ what HRE recommends they noe best!!
btw:: have ya any pix. of these HRE wheelz ur usin'???
Old Jun 10, 2006 | 02:04 PM
2perCooper's Avatar
2perCooper
since you are getting HRE's, which use custom offsets, you will be able to fit a 225/35-18 on there. I did. I ran 18x8 JLine SDMSL2 with 225/35-18 Goodyear Eagle F1 GS-D3. Lowered on H&R Springs and no rubbing at all.
Old Jun 10, 2006 | 03:17 PM
Yangsen's Avatar
Yangsen
while researching for a set of 18x8 Hamann's, I was recommanded to go with the 215-35-18.
i am still thinking hard about the set. can you breifly explain the "stretch" problem? should that be a concern for me?
the hamann's come with a 43mm offset.
Old Jun 10, 2006 | 04:05 PM
J0kER's Avatar
J0kER
tha more u stretch a tyre tha less protection u will have for ur wheels when u hit a hole intha road(less rubber to break impact), tha more lip u have on ur wheels the weaker tha rim/wheels tend to be.
on those HAMANNS u speak about they are heavy duty so even tho they kinda have a deep lip u should be fine, its a strong wheel to begin w/. light weight is not always better...
Old Jun 10, 2006 | 04:08 PM
J0kER's Avatar
J0kER
they r tellin' u this cuz of tha offset
Old Jun 11, 2006 | 10:48 PM
Yangsen's Avatar
Yangsen
Thanks for the feedback!
kazyn
Oct 25, 2019 02:34 PM
Mini'mon
Aug 16, 2015 04:15 PM
Mini'mon
Aug 16, 2015 12:47 PM
Edgar78
Aug 15, 2015 05:33 AM
Rennfahrer555
Aug 13, 2015 09:07 AM
