Most aggresive offset?
Old May 17, 2006 | 07:59 PM
  #26
Tahoe T's Avatar
Tahoe T
This thread has a lot of the info that I was looking for, but I have one more question. If the S-lights I am running now have an ET50 and the 16"X-lights have an ET48, even an ET in the 40-42 range seems very different. Will a 42et wheel be enough to increase bearing wear enough that I would notice?
TT
Old May 18, 2006 | 01:35 PM
  #27
Alex@tirerack's Avatar
Alex@tirerack
TT
If its hubcentric, no premature wear should occur.
Alex
Old May 18, 2006 | 08:13 PM
  #28
Tahoe T's Avatar
Tahoe T
Alex
Great!
Thanks Alex.
TT
Old May 19, 2006 | 05:30 AM
  #29
meb's Avatar
meb
Every 13mm is equal to a 1/2".
I have 38mm offset on my BBS wheels and I have 56k + miles on my 05. No problems so far...my track wheels are 45mm offset.
Offset affects a few other things as well.
Old May 19, 2006 | 07:21 PM
  #30
Tahoe T's Avatar
Tahoe T
Meb,
Thanks for the conversion and the personal experience. Good to here that a 38mm offset hasn't caused any problems. I know that 6-10 mm is not much in absolute terms, I was figuring that the engineers that designed the MINI must have had some reason to use the offsets that the did, and was a little concerned about making any big changes. Not being an engineer myself I didn't know if 6-10 mm was a signficant difference.
TT
Old May 20, 2006 | 06:13 AM
  #31
Arly's Avatar
Arly
alex (tirerack),
i have a set of bbs rgr 17X7. What is the offset of these? I recall an offset close to this.
Thanks,
Carl
Old May 21, 2006 | 07:58 PM
  #32
RallyMINI2005's Avatar
RallyMINI2005
Saw this post had been revived...
...and I thought I would let everyone know that I am still driving around on these wheels. I trimmed the fender wells back such that they don't rub, though during extreme impacts (like backing over a curb once) they _can_.
The driving experience is actually just fine. I put my S-lites back on the other day (for a dealer visit) and realized just how bad those wheels are! The torque steer I was attributing to my new wheels is NOTHING like it is with the S-lites.
In fact, I think the tramlining effect is much worse with the stock wheels. I was frightened more than once after the wheel was yanked left or right by a big rut in the road! (YAY worst roads in the country!).
Overall I have had no major problems after 3000 miles. I am still looking for an engineering diagram of the MINI front hub so that I can do some calculations on the moment induced in the wheel bearings. This will give me an idea of how much more load I am putting on the bearings, and if I should be worried.
ciao,
RM2k5
Old May 22, 2006 | 06:03 AM
  #33
MisterDangerPants's Avatar
MisterDangerPants
I wouldn't mind stopping by and seeing how you trimmed the fender wells, as I'm experiencing the same effect on our lovely roads! I'm running a 7.5" ET35 wheel, so I'd like to eliminate the little rubby-dubby I occasionally get (especially the dips on Gray Street!).
bahman
Aug 6, 2016 07:19 AM
Chibi2
May 19, 2016 03:46 PM
Amberleigh MacIntyre
R55 :: Clubman Talk (2008+)
Nov 11, 2015 11:59 AM
vbmike
Oct 15, 2015 04:32 AM
