offset help
offset help
Try as I might, I can't seem to get a grip on this offset business. I simply don't understand it. I am trying to find a 17 inch wheel that is ""G Stock legal. My "stock" R85 S-lite has a off set of 50mm. The new wheel I am considering (14.1 lbs!) has a offset of 42mm. The SCCA rules allow for a maximum offset diffrence of +/- 0.25 inch variation from standard specs. Where the heck am I with this 8mm diffrence? Is there a way to adapt this wheel via shims etc into SCCA compliance?
Here's a link to look at the effect of offsets- http://search.netscape.com/ns/boomfr...heel+offset&pa
I think the wheel you're considering is beyond the .25in. allowed. (25.4mm=1in. so .25X25.4= 6.35mm.) I think you'll need a greater offset to fit the regs- like 44 or something like that- but I could be wrong!
Sorry, that link doesn't seem to work. Try this-
http://www.1010tires.com/WheelOffsetCalculator.asp
Thanks. So, if I read the calculator correctly, they advise to "extend" offset an extra 8mm, which I could do with wheel spacers, if I could find somthing between 5 & 10mm. (good grief, that's a stretch lol!) Sound right? I will run this by the "G" stock site. Thanks for your help.
Yup. The Team Dynamics wheels will work nicely. Any one have any comments about the Pro Race 1 and the Pro Race 2 designs and reliability?
I have the Pro Race 1s with Toyo Ra1s. The wheels are flat black. 45mm offset. They look very good on a pure silver car. PR1 is lighter by a couple of pounds than the PR2s.
I think the real question is, what is considered stock offset? There is a range, I beleive, that opens the door for some interpretation...perhaps not.
My summer wheels are BBS RGRs. These have a 38mm offset...basically a 1/4" difference.
Chibi2
May 19, 2016 03:46 PM
Amberleigh MacIntyre
R55 :: Clubman Talk (2008+)
Nov 11, 2015 11:59 AM
vbmike
Oct 15, 2015 04:32 AM
