Does BBS make an 18" to fit the MCS?
Originally Posted by jonsibal
Not true, magnesium is still lighter. Trust me on this one
The new GT2 is made out of forged aluminum centers which make them stronger than the magnesiums which is definetly a plus. They both use the same outers and inners though as well as the very desireable titanium fasteners.
Mario, I got my info directly from BBS - Motorsport Division. I was actually sponsored by them for a while there and had a pretty good rapport with the head of the motorsport division. Unfortunately he no longer works there. But they were always helpful when I call, even now.
According to their notes, the weight of the forged aluminum CENTER is slightly heavier than the cast magnesium center. Note that this is only for the centers not with the 2 rim halves. The difference is not that much but "technically" they weigh differently.
Different combination of outers and inner rim halves can also vary the weight if you measure them assembled. The outers comes in TA-35, TA-40, and TA-50. and the Inner comes in TI-40 and TI-50. The T stands for Type and the A stands for äußer which is German for Outer. I stands for Inner.
The numbers represents the thickness of the material;
TA-35 is 35mm
TA-40 is 40mm
TA-50 is 50mm
TI-40 is 40mm
TI-50 is 50mm
Obviously, if all else is equal, the thicker the material, the heavier it would be.
So for example, if the forged aluminum wheel is using a TA-35 and TI-40 rim halves while the magnesium wheel is using a TA-50 and TI-50, then with this combination, the aluminum will come out lighter. BUT if both are using the same inner and outer part #s then magnesiums should come out lighter.
This is how I understood it. I'm not an expert on this or anything but I just had to learn all this when I was ordering my wheels and helping a friend out get the new forged aluminum version.
When I ordered mine, the aluminum version wasn't out yet but IF I would get another set again, I would opt for the forged aluminum. I can post more info about their forging process but this is getting too long. I would run the GT2 in my wife's mini but man, they are $$$.
Anyways, hope this info helped.
TA-35 is 35mm
TA-40 is 40mm
TA-50 is 50mm
TI-40 is 40mm
TI-50 is 50mm
Kimolaoha
Jul 5, 2023 01:04 PM
SosoMINI
Nov 22, 2015 03:17 PM
Mini'mon
Aug 16, 2015 04:15 PM
minipopkart
Aug 13, 2015 05:22 AM
