06 MCS runflat tires suck
Originally Posted by Dr Obnxs
Do you really mean to say that you think the Stock Run-Flats stick as well as high performance rubber? Do you think that extents to race compound tires as well? Where's your proof that they stick as well, other than saying that you're happy with the traction? What compramise do you think the manufactures made to get the run-flat capabilities? None?
Like I wrote above, compliance is shared by the springs, dampers and tires. You can soften any of these and the ride will more than likely improve.
If you figure that 25% of suspension compliance comes from the tires - and that's an engineering threshold by the way - there is much more to be gained by playing with springs and dampers. However, all three must exhibit frequencies that harmonize in the real world if they are to handle well, and, ride well.
BMW placed a high emphasis on the Mini's handling. Still, suspension R&D money isn't limitless and at some point the folks dangling the purse strings say stop. I believe this is the case with BMW; their cars have been lauded for the most incredible ride vs handling trade off for the last two decades. The Mini's suspension, in my opinion, is and will be an unfinished project...till the next one...
I still don't see shocks as a solution for the guy's tramlining... He found a solution (new tires) and apparently is happy with it...
Above was to Stevie B, but meb, if the huh was directed at my prior post I was just wondering what tires (rfs or not) when they do the runs to determine the published zero to 60 times for BMWs and Minis.
The point of a runflat on a high performance car is to allow a puncture at a higher speed and have the sidewall not disintegrate and support that car at a lower speed up to 150 miles and then be repaired.You cant and shouldnt do a comparison to a regular high performance tire because you are comparing apples and oranges .The run flat tire by design is heavier because it has more material to support the sidewall after deflation this isnt by choice this is the way they support the car and not have the tire run off the rim.Unfortunately if you talk to a tire manufacturer his biggest problem is getting a customer to even check tire pressure,never mind rotate tires,so they definitly build the tire to sustain the abuse.The stiff ride of the runflat is the result of its design to run flat, the short travel of the suspension ,and the stiff springs.Most people around here have a set of tires for the autox and or competition and another set for the daily commute.Celebrate the difference because they are designed for two different situations.
Originally Posted by hoopi
it's important for anyone reading these posts to understand that swapping the RF's for regular tires is removing a safety feature.
Originally Posted by micahbones
My all-season run flats were horrible in snow, which in my mind made them a much less safe tire than my current Dunlop non-run-flat peformance winter tires in adverse conditions (of course I do not have the comparison of a dedicated run-flat snow tire).
I would also argue that a non-run-flat performance tire is better in an emergency handling situation that does not involve a puncture like a swerve of sudden stop because of the non-run-flats lighter weight and better roadhandling ability.
My all-season run flats were horrible in snow, which in my mind made them a much less safe tire than my current Dunlop non-run-flat peformance winter tires in adverse conditions (of course I do not have the comparison of a dedicated run-flat snow tire). I would also argue that a non-run-flat performance tire is better in an emergency handling situation that does not involve a puncture like a swerve of sudden stop because of the non-run-flats lighter weight and better roadhandling ability.
As for the run-flat vs. non-run-flat roadhandling ability, that debate continues... I still maintain my belief (remember, it's a belief, I'm not claiming God-like knowledge here, so it's until proven otherwise) that for handling ability, a stiffer sidewall is a benefit. That doesn't mean that you can ONLY get a stiff sidewall with run-flats, of course not... but it does guarantee that you will ALWAYS get a stiff sidewall with run-flats.
Points taken fellas. Based on the criteria that I deem important: performance, weight, cost, and safety -- I chose to lose the run-flats and will never go back to them until they are of comparible performance, price (they are significantly more expensive), and weight (e.g., people spend hundreds to lose a couple of pounds from their wheels, but arguably the weight of the tire is even more crucial because the tire is further from the hub -- and therefore has an even greater rotational effect than the wheels). For me the safety issue really is a wash...
we're all **** for accuracy :wink:
Originally Posted by meb
Well thanks for the slamming guys...gals?
I was thinking 20lbs per axle and some how multiplied this by four. In reality, the difference is 13lbs per wheel, a significant, if not sobering difference for a 2,563lb car.
26lbs for the stock 17 wheels + 23lbs for the run flats vs 20 lbs for the Michelins and 16lbs for the BBS RGRs. 49lbs vs 36lbs. 52lbs of spinning weight...I call that a lot.
Tire compliance figures into suspension tuning at some point, or it ought to. A stiff spring and damper combo will typically work well with a tire that has a stiff sidewall - the compliance rates of these three components must match up within some window.
Matt
Let me know if I'm not allowed to have opinions and I'll stop.Happy holidays...Cheers!
Originally Posted by Stevie B
True, but the attack was on RFs and tramlining is a factor of tread design. Glad he's happy. I certainly don't think yours or my opinions should have any bearing on what he can or can't purchase, or what's he's allowed or not allowed to like. We're all just expressing opinions here and I reserve the right to express mine while I'm over here in Germany defending your right, but for some reason you won't rest until you have the definitive answer??? Anyway, time to agree to disagree and press on. I don't think he needed rescuing. As you say, he's happy. Ultimately, I just didn't find the action logical and therefore commented. I also find the wheel/tire weight debate interesting. Shaving weight is great, but some will spend upwards of $3000 to shave 10 pounds a corner, and claim it transformed the driving experience. Well, it didn't, but a step (albeit expensive) in the right direction (that had as much to do with appearance desires as performance gains). Here again, to each his own. To throw in my input, I'm of the opinion (key word) that more capable shocks would have an enhanced positive affect on tracking/cornering over real world surfaces than reduced unsprung weight with all else equal. Just opinions...you can put the gun down now!
The Saga Continues
Hey Guys. I should rephrase in my previous title. about the RSC tyres. I dislike them. Its funny how so many guys here think I have a suspension problem,and they know the cure. I don't have a suspension problem. I know tyre pressure. I am a factory specialist for Mercedes Benz for 18 yrs this is what I do.I drive hot cars all day long. about the safety issue. With our mini's or any other car for that matter. If I blow a tire. since I dont have runflats any more. I am not going to drive it for 150 miles.
case in point. AMG E55 No runflats very safe car. Has a can of goop for the spare. A 90K Car. Gee what happened to safety @ a 120+ mph.
Some guys here may think I wasting my money. I don't think so, your right I am fresh with being a new mini owner. But If I am driving on the Hwy, and my car makes me feel nausous, I need to do something about it quicky. It really did have alot of side to side movement.
My tyre pressure were perfect. @ first when I picked up the car for deliver check the tyre pressure the next day cold. the darn things were 48 psi in the rear 38 in the fronts. I reset them to 33 psi all the way around. Still same problem. Around town was acceptable but the FWY it wondered too much. It stuck around turns with the runflats and w/o it still sticks. So bottom line if someone is experiencing what I was feeling on the FWY. and does not like the feel. Tires will cure it,not shocks not swaybars,or strut braces. Just tires.
My 2 cents thanks guys and gals. But Man what a great thread.
No need for bold...
It hurts the eyes.
I agree with everything you just wrote. I didn't like 'em, but drove them till they were shot before going to something else. Both the other typed didn't track on the freeway, and near where I live there's even that groved concrete. The stock tires tracked very,very badly.
It's funny that a lot of people who don't agree with posts think that there is something fundimentally wrong with the original poster, either they're an idiot or didn't use the product correctly. I'm no expert driver, but I can feel when a tire is low by a few PSI on my car. And I ran at good pressures (but to be sure, the rear pressure doesn't matter nearly as much on the Mini as on some others), and I'm very happy I switched, and will never go back.
It's also fine that others like them too! Otherwise I couldn't have sold a set given to me!
Vive la differance!
Matt
Vive la differance!
Matt
I haven't driven our 06 MCS with anything but the factory 17" performance runflats (Dunlops), so I can't claim a comparison. That said, I have not had a negative experience with them. They handle fine, I have experienced no tramlining, the car corners like it's on rails, etc., etc. I will consider going with something else when replacement time comes along, but I can't see replacing brand new tires (with a retail value of nearly $1,000) with something else based on my experience so far.
You know what I was thinking maybe. It was the perrilli runflats. Thats what I have on my car. Other owners have dunlop and do not experience the same effect. Hmm just a thought
Happy Holidays
Guido
Happy Holidays
Guido
Happy Holidays
Guido
Happy Holidays
Guido
Merry Christmas!
Cheers!
My Pirelli run-flats are horrible. The tramlining problem is quite serious and I have to hold onto my steering wheel pretty tight all the time. Even my wife is complaining about it (which she drives the car more than I do). I guess I will have to think of changing them very soon.
From what people with Euforias have said, the tramlining goes away quite a bit as the tire wears in. Make sure your tires are at the proper PSI too. Mine (Dunlop SP Sport 9000s) came at 38 PSI from the dealer, so I reduced it to 33 PSI right away. I don't think the PSI will affect Tramlining too much, but I'd set everything to "stock" to remove the other variables. How many miles do you have on them? I have 3100 on my Dunlops and I have no complaints. I understand the Bridgestones are far closer to the characteristics of conventional tires. Can't wait to hear some testimonials.
I have been very happy with the performance of my factory runflats (Dunlop SP Sport 9000s), and I just bought a set of runflat winter tires (Pirelli Winter 240 SnowSport RFT) that I am very happy with as well.
The winter tires don't bite as well as my performance tires on dry pavement (duh!), but they do feel fine otherwise, and I'm looking forward to really tearing it up on snow when the next storm hits!
tires just keep rolling
Hi Steve. I rephrased it> its sucks ) to dislike in my last post. Thanks for the comment. Tell me how do you like the LSD. I screwed up and forgot to order it. I don't track my car, I just like driving through the canyons here in southern calif. So I am just curious. Do you track yours do you see a advantage or disadvantage for having your LSD.
As you read I installed P Zero's and very
I was in germany a few Yrs back. I trained out in Stugartt. Underturkheim<is that right. Aslo toured Alfalterbach. Trianed @ Lorinser and a few other tuners in the Swabian areas.
See you happy holidays.
Guido
. I was in germany a few Yrs back. I trained out in Stugartt. Underturkheim<is that right. Aslo toured Alfalterbach. Trianed @ Lorinser and a few other tuners in the Swabian areas.
Guido
They make for a cheap (if heavy) set for track days, so I don't have to fret about trashing my everyday tires.
And when they're worn out, I'll sell the rims to somebody who can't resist the lure of 17" wheels for cheap!
Hi Eric
Originally Posted by Eric_Rowland
Hey, why you lookin' at me?
Matt
