Changing brake hoses
Old Jul 22, 2005 | 06:41 AM
Stu(pid)'s Avatar
Stu(pid)
In the Bentley manual it mentions using a special BMW tool to depress the brake pedal slightly to prevent fluid loss when changing the brake hoses. Has anyone tried this? How much is "slightly"?
Old Jul 22, 2005 | 07:29 AM
bluesmini's Avatar
bluesmini
i think that might be just to prevent sucking in air when you brake the hoses loose. it's a messy ordeal. brake fluid is very corrosive.
my special tool is my torque wrench. i slide the seat up to hold the wrench between the brake pedal and the seat. not much pressure but enough to hold the wrench there.
this also reminds me to torque my wheels before i drive off. yes, i have forgotten in the past.
Old Jul 22, 2005 | 08:34 AM
petecrosby's Avatar
petecrosby
I believe pushing the pedal down a little bit pushes the master cylinder piston beyond the feed holes from the reservoir, preventing the fluid from just draining out through the opened brake line. It also creates a small suction on the line, much like putting your finger over the end of a straw filled with liquid.
Old Jul 25, 2005 | 11:31 AM
Wesport's Avatar
Wesport
It does seem to help. I had my rig slip and fluid bagen dripping out prety fast. Once I jammed the pedal again it slowed almost to a stop.
Old Jul 25, 2005 | 06:28 PM
toddtce's Avatar
toddtce
While I cannot confirm this on the MINI it is the case on the SRT4. The description is pretty accurate.
Kimolaoha
Jul 5, 2023 01:04 PM
tr3y003
Oct 22, 2015 10:48 AM
JPMontes3
Aug 23, 2015 01:26 AM
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
