Tire Size Question
Old Jun 6, 2005 | 06:26 PM
resipsamcs's Avatar
resipsamcs
Tire Size Question
I know that there is alot of info. already posted in other threads regarding tire size choices, but I still have a few questions. I am currently running Flik Wasp Wheels, 17x7, 42et, with Toyo Proxes 4 tires in 205 45 17 on a MCS with H-sport springs. I will need to replace these tires in the not too distant future, and was wondering if I should keep the same size or switch to 215 45 or 215 40 tires. I d/n want any rubbing issues of course, but like the idea of a little bit more width. I d/n want to push load ratings, but I am confused b/c of conflicting info. about whether 215 40 is or is not w/in the MINIs load rating. Other than the difference in appearance, are there significant performance pros/cons between the sizes?
Old Jun 6, 2005 | 06:38 PM
ripley's Avatar
ripley
yes, you're right. there's numerous threads about this. your best bet is to call Alex at the Tire rack. he can answer your questions.
ripley
Old Jun 7, 2005 | 10:23 AM
Alex@tirerack's Avatar
Alex@tirerack
215/40 meets your gross axel weight requirment,
(dry, no passengers, not moveing... no fun)
However removes additional load bearing capacity that protects your wheels from damage -
The OE fitment had a reserve built into it.
Alex
Old Jun 7, 2005 | 04:31 PM
resipsamcs's Avatar
resipsamcs
Thanks Alex - would 215 45s present rubbing issues and is there any advantage/disadvantage over 205 45s?
Len
Old Jun 7, 2005 | 09:42 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Len
Given your rims and lowered suspension you are better off with 205/45-17 tires since the 215/45-17 tires can rub in the rear wheel wells but it can depend on which tires you choose and how much negative camber you have in the rear.
205/45-17- safe choice/stock sized. Lighter weight and maybe lower cost for tire. Should work fine for street use and some performance driving. Runflats that fit the MINI come in this size. Selection a little limited for non runflats
215/45-17- potential for rubbing (slight- I just let it rub the inner lining of the wheel arch and pretty soon the plastic is gone but it did rub my tire a bit). Heavier tire- only a little, 10mm wider and outer tire diameter is 24.6" tall. Much better selection of tires available across many brands. No runflats in this size.
215/40-17- Good performance tires, good selection of tires, rougher riding and less chance for any rubbing. If you often drive with passengers it's not a good choice due to lower load rating as mentioned. Can be more expensive within a model/brand.
Old Jun 8, 2005 | 09:54 AM
Zarrik's Avatar
Zarrik
In the same theme, is there any difference between 205-40-17 vs 215-40-17? I was looking to get the new Falken RT-615s, but couldn't determine which size would be better for daily driving, and limited Auto-X use. (On stock suspension).
Old Jun 8, 2005 | 01:31 PM
Alex@tirerack
Len
Advatage wider tread pattern and more choices
rubbing - depends on wheel width and offset
Alex
kazyn
Oct 25, 2019 02:34 PM
col127
Aug 21, 2015 02:11 PM
Mini'mon
Aug 16, 2015 12:47 PM
Edgar78
Aug 15, 2015 05:33 AM
