What would you want for the perfect brake upgrade.
I'd like to see an optimum sized crossed-drilled and slotted rotor for use in a 16" wheel. If you are developing the rotor from the ground up it would be cool to see the slotted portion create some type of design...like the word "MINI"...or branded logo or something. I'll get bigger brakes for stopping power, but which brakes I get will probably be based--as superficial as it is--on the aesthetics of the rotor and caliper.
There's a number of good kits on the market. From a business standpoint, I'd try to fill a niche that's not currently taken, unless you feel that you provide either higher quality or lower price (or both) than the current lineup.
Personally, I would like to see something with blank rotors... none of this slotted or drilled hype. I also wouldn't consider purchasing anything with Wilwood calipers.
Something that didn't require 17's might be nice. A quality kit that fit under 15's would as well, but the market for that would be extremely limited.
I'd like to see the biggest brake kit for the front and rear that will clear both the O.E. 16's and 15x7.5 SSR's. I took measurements on both of these at one time and the SSR's had more room than the O.E. 16's so if you are thinking more along the line of fiting to the 17" O.E. wheels then I'd still like them to work with the 15x7.5 SSR's.
Hmmm.
Much of what you are asking for is already out there. Guess you aren't looking hard enough.
I did a spread sheet on this platform and provided a list of the kits out now for the MINI. There were about 12+ of them if I recall. And one for every preference.
There are singles, twins, fours, sixes, and even ten pots.
There are 11-13" rotors at least and about four sizes in between.
There are widths from .75 to 1.25 (or more) to choose from.
There are kits from $800 to $3000.
There are some that take bias into account, some that do not.
There are in colors, some not.
There are some with holes, slots, both, neither.
There are some with zoomy mill work.
There are floating rotors, and fixed rotors.
There are two piece and one piece rotors.
There are zinc plated kits, some not.
There are radial mount kits and tab mount kits.
There are kits for 15s and kits for 17s.
There are kits that clear stock wheel, kits that don't.
Ok, you're probably tiring of this by now. But I have the facts to back it up too. And details on most of them pro and con.
As for one brand being better than another; bunk. First off this is not a difficult car to work. The dynamics of the car pose no real threat or challenge to those in the brake kit industry. There are pros and cons to all the choices you have now. And there always will be.
The anwer to your question (and not one I'm taking issue with at all) is that in every case the real answer will be "a kit to fit my requirements". And that my friend is choice. Covered very well by what's on the market now.
The other comment will be the one you'll soon gloss over: "massive floating rotors, big pads and giant calipers. Fitting the stock 16" wheel and costing much less than what is on the market now, maybe sub $100" Sadly it doesn't work that way. For every plus there is a minus. Period. Don't care who's name is on it. Show it to me and I'll point out its down side.
It's like buying tires folks, there is no simple answer or one size fits all application.
And as for the comment of no WW parts; that's fine, but be sure you compare apple to apples when making that statement as many of the products soundly trounce the competition in many ways.
* I am in no way discouraging a new product. From where I sit, the more the better. Just do some market research on what is out there now.
Had to add a couple more thoughts as this is a very interesting thread.
The comment for a drilled and slotted rotor or one with MINI in it is cool. But beware; there are those who will laugh at that! So what? It's what you want.
The comment that there are many kits out now that fit 17s and not 15s...well there's not much you can do about that. But there are alternatives too.
No more slots? Oh my. Now that makes one a rebel! lol That's cool, nobody really 'needs' the slots but few folks don't 'want' them when it comes down to it!
My point? That there are so many different things that ONE person wants in a product like this that even in five posts you see them 180* apart!
I recently spent time on an 'alternative' too. The plan was for a $450 kit. And you know what? It turned out to be a bust. I re looked at the idea of a caliper only kit to the stock rotor. Not going to happen in my book. The reason is both fit, clearance, value and quality in the final product.
All of those issues will be dealt with on any new product. And let's not forget that any business doing this is in it for a profit.
Originally Posted by XAlfa
Are talking about modifying the software as well? I thought the EBD code controlled brake bias.
Originally Posted by toddtce
Hmmm.
Originally Posted by MiniPilo
Brake Bias can be controlled by altering the ration of brake piston size between the front and rear. Most likely, we would make the car a bit more rear biased, because the mini really uses the front a bit too much.
I want brakes that will work with 15 inch SSR Comp wheels (in 6.5 inch width). And something that will improve on stock stopping distances, for mostly street, but some autocross and track days. Rotors front and rear, with matching calipers -- good looking ones. And lighter than the stock set up too is a must. I'm probably dreaming, but ceramic would be ideal, if it meets the above criteria.
OK. let me describe my dream brake system:
two-piece 4-pot caliper (forged aluminum, not cast) (or reinforced aluminum monoblock, but 2-piece preferred)
commonly available pads
300-310mm floating, vented, solid-plate rotor (assume this is largest rotor that will fit 16" wheels, although bigger is always better-as long as it fits most 16's)
something that won't brake the bank. I think a fair price would be in the neighborhood of $1500-$2000 ('cause you get what you pay for-most of the time)
now all of this may already be out there, but those are the specs that I would certainly drool over.
marendt428
08-08-2015 04:44 AM
