Wider tires/rims
Wider tires/rims
Looking to get wider tires/rims on my 2013 R56. Right now it’s got 205/45R17. What size have you guys put on? I was thinking of keeping my rims and just putting some Falken 205/50R17 on
@njaremka wouldn't you have to go down to 40 if you're going up to 215 and then even lower to 35 if you go up to 225?
225/35-17 search at tirerack.com gives Zero results
205/45-17 fits rims 6.5 - 7.5" wide, perfect for 7" wide rim, tire diam 24.3"
205/50-17 fits rims 5.5 - 7.5" wide, perfect for 6.5" wide rim, tire diam 25.1"
215/45-17 fits rims 7-8" wide, perfect for 7" wide rim, tire diam 24.7"
For racing, Extreme Summer tires
215/40-17 fits rims 7-8.5" wide, perfect for 7.5" wide rim, tire diam 23.8"
From these, tire selection may be limited depending on which tire you are considering. 25.1" tire diam. is tall but some owners have used it on an R56. It's too tall for an R53.
215/45-17 is the more common solution and is widely available. 215/40-17 is more limited and favors race or DOT 200 treadwear tires which are stiff riding, noisy and wear faster, but that tire size will work.
All of these will fit OEM 17x7" rims.
Nobull60
Tires, Wheels, & Brakes
Mar 20, 2003 07:54 AM
