R56 Base Donut Spare Valve Stem Size
Old Jun 27, 2019 | 11:04 AM
bugeye1031's Avatar
bugeye1031
Moderator
Working with a 2007 R56 Base with a space saver spare and I need to replace the valve stem and the valve stem extension because they have rotted out. The valve stem extension has welded itself onto the valve stem. I'm told that the hole in the wheel for the valve stem is smaller than normal, so it takes a smaller valve stem. Does this make sense?
The MINI dealer doesn't have a special valve stem for space saver tires, nor does RealOEM or ECSTuning....at least that I can find.
The part number for the valve stem extension is 31 10 6 783 425....$32.50.
Old Jun 27, 2019 | 11:12 AM
DneprDave's Avatar
DneprDave
I'm sure that any tire shop would have valve stems for space saver spares, there are a lot of cars that have spares like that.
Old Jun 27, 2019 | 12:28 PM
Just check and https://www.ecstuning.com/b-genuine-...h/36121116326/ works with https://www.ecstuning.com/Search/Sit...h/36111509164/
We also now mount and MINI spare tires with wheels its linked under the https://www.ecstuning.com/Search/Sit...h/36111509164/
Psjoe Eojsp
Mar 26, 2019 11:42 AM
STLMINI
Tires, Wheels, & Brakes
Jan 25, 2011 06:42 PM
Prost
R55 :: Clubman Talk (2008+)
Apr 6, 2009 08:56 PM
mf44
May 16, 2008 05:21 AM
popimor
Aug 27, 2007 06:12 PM
