ABS and Traction control warning lights on after replacing shocks and struts
Hi Guys, I just replaced the shocks and struts on my 05 MCS and the warning lights for the ABS and Traction control are on now. Is this just something came unplugged or is a sensor damaged?Any insights would be appreciated.
I checked the front sensors because apparently that's where most of the issues occur and found that I forgot to reinstall the ABS sensor wire into the holders closest to the motor. There was enough slack to allow the wire to get chafed on one of the pulleys. Long story short, I separated the wires and went crazy with electrical tape. Problem solved!
ewgoforth
75
Nov 25, 2023 04:50 PM
imncrxtc
16
Apr 6, 2016 11:37 AM
chrunck
Suspension
Jan 10, 2011 12:32 AM
