APEX ARC-8 17x8" ET25 - INSTALLED
Old 08-27-2018, 10:44 AM
Dr. Spade's Avatar
Dr. Spade
Dr. Spade is offline
Originally Posted by tallskinnymatt
Thanks!
Thanks! The 595 RSRR do run quite wide, so a 215/40-17 would require quite a bit more negative camber and more of a fender trim in the rear to get those to clear. Doable, but I did not want to run that much camber. Also the RSRR is a very loud tire, so not something I wanted to deal with on a daily basis. However, you're absolutely right. it would perform much better on track! However, the ST-1's handled surprisingly well. It was only on session 4 where they got a bit hot and I started slipping a bit.
I'd love the concave 8.5' wheels as well, but not enough clearance unfortunately. I did see a guy with an R56 use fender flares with the 17x8.5" ET20 and they looked great!
Yea, Federals in general run wide and RSR/RSRR in more so.
FYI you can still buy the older RSR. I bought a set of RSRR and RSR within the last month. Got the RSR for my daily VW because they are MUCH quieter than RSRR.
  #27
Old 08-27-2018, 10:48 AM
tallskinnymatt's Avatar
tallskinnymatt
tallskinnymatt is offline
Oh great info! Might consider those for my next set Federals are the best bang for the buck tire in my opinion. Couldn't be happier with my ST-1's!
LostbutFound (07-30-2019)
  #28
Old 09-18-2018, 11:25 AM
BumpDaddy's Avatar
BumpDaddy
BumpDaddy is offline
Thanks a ton for posting these pics. I have been doing tons of exhausting research on rims/fitment/tire size, etc. I must have looked at a zillion wheel/tire combos. I just can't get past how perfect these look, so I basically decided to bite off you and buy the exact same everything. Unfortunately, just my luck. It looks like APEX is sold out of wheels in this size except for one last set of their "hyper black" color. I reached out to them today to ask when they'd have more satin black in stock. I have a BRG R53 with a black roof and I'm sure it would awesome with the satin black. Hoping for some good news from them.
  #29
Old 09-18-2018, 05:23 PM
tallskinnymatt
No problem! I think the 17x8" ET25 is a perfect fit for the Mini with some camber dialed in front and rear. The Hyper Black is a fantastic color, and looks like a dark silver/metallic color. Hope it works out for you
  #30
Old 05-31-2019, 02:26 PM
o2sys's Avatar
o2sys
o2sys is offline
Are the wheels poking a little bit?
Do you think I can run 205/45 or 215/45 with the similar stance as yours?
Just want some more sidewall.
  #31
Old 05-31-2019, 06:56 PM
tallskinnymatt
The wheels did poke out when I was at stock height and didn't have any camber dialed in. With the camber, the wheels just tuck into the fender. Super flush fitment. I thought about running 205/45-17's, but with this aggressive of a stance and how low it is, it would rub inside on the fender. If you stay at stock height you may be able to get away with 205/45-17, but I cannot confirm.
  #32
Old 05-31-2019, 08:18 PM
Joshua P's Avatar
Joshua P
Joshua P is offline
I really want these wheels! I hope they do a sale on them again soon.
  #33
Old 05-31-2019, 08:22 PM
tallskinnymatt
There are more in stock if you’re interested I recently sold the car, but already miss it and miss the wheels!
  #34
Old 06-02-2019, 06:50 AM
Joshua P's Avatar
Joshua P
Joshua P is offline
That would be awssome especially if i could still get the sale price.
  #35
Old 06-10-2019, 01:07 PM
o2sys's Avatar
o2sys
o2sys is offline
How much camber are you running?
  #36
Old 06-10-2019, 01:25 PM
tallskinnymatt
-1.7 degrees up front, and -2.6 degrees in the rear
  #37
Old 07-29-2019, 04:38 AM
bradkara124's Avatar
bradkara124
bradkara124 is offline
Lowered the rear a bit more, and had my alignment done. Currently at -1.7 degrees up front, and -2.6 degrees in the rear. The rear rubbed slightly on large bumps, but I shaved a bit of the plastic and hasn't rubbed since. It's finally sitting how I envisioned it
Damn those look amazing !!! I'm ordering my next next payday 17x8 et25 but with the 215/45/17 tires ! Cant wait yes yes
  #38
Old 07-30-2019, 06:37 AM
Minibeagle's Avatar
Minibeagle
Minibeagle is offline
Originally Posted by entropy1
I don’t comment often, but I do when I see such proper fitment as this. One of the best looking aftermarket setups I’ve seen on a Mini. Very well done. Love the flat face of those.
I have to agree with this statement. Beautiful stance and wheels.
  #39
Old 07-30-2019, 06:44 AM
o2sys's Avatar
o2sys
o2sys is offline
Inspired by your setup, recently finished mine, just waiting on my center caps to be done as well.
Not as aggressive, will lower the rear a bit more soon after I get an alignment.
BBS RC 17x7 ET42:
Joshua P (10-10-2019)
  #40
Old 12-29-2019, 10:06 AM
R53Madness's Avatar
R53Madness
R53Madness is offline
How bad is the rear tire wear with -2.6 degrees?
  #41
Old 12-29-2019, 10:12 AM
R53Madness's Avatar
R53Madness
How bad is the rear tire wear with that much negative camber?
  #42
Old 12-29-2019, 12:28 PM
tallskinnymatt
BBS RC 17x7 ET42:
Looks great!
I sold the car after only 6k miles with this setup, but tire wear was not bad. As long as you zero out the toe, you’ll be fine. Toe has a much greater impact on tire wear than camber. Anything under -3 degrees is very livable.
  #43
Old 04-17-2020, 07:15 AM
Nathanlloyd's Avatar
Nathanlloyd
Nathanlloyd is offline
Are you using the MeisterR ClubRace Coilovers, or MeisterR ZetaCRD Coilovers. Or the more fancy ones?
  #44
Nathanlloyd
sorry about the font, dunno what went wrong...
  #45
Old 04-17-2020, 02:00 PM
tallskinnymatt
I ran the MeisterR ZetaCRD+ Coilovers Nothing but good things to say. They are a great entry level/daily driver suspension system. I believe they are made in the same factory as BC Racing coilovers, since they look identical aside from the colors.
tallskinnymatt
Tires, Wheels, & Brakes
05-02-2018 08:25 AM
cmanlu
11-02-2014 11:48 PM
RedAndBlackMiniS
01-25-2012 06:06 PM
barnoun
03-21-2011 11:42 AM
mini_macky
03-13-2008 10:49 AM
Quick Reply: APEX ARC-8 17x8" ET25 - INSTALLED
