How to replace rear calipers?
Old Mar 23, 2017 | 06:00 PM
Greenmachine13's Avatar
Greenmachine13
Hello, I'm working on my 2003 Mini Cooper S and I'm stuck on the replacing my rear calipers. How do I remove the rear brake line as well as the emergency brake line going to the caliper?
Thanks again for for the help!!!
Old Mar 24, 2017 | 08:49 AM
Rear brake cables:
https://www.northamericanmotoring.co...in-an-r53.html
And
https://www.northamericanmotoring.co...r-caliper.html
The lines you will need correct size wrench to fit the line and pop it off. make sure you cap the old line to not let air in and then after you done and its attached. Bleed the line.
https://www.northamericanmotoring.co...e-lines-430863
