Non-Run-Flat Road Kit - what is everyone running?
Old 02-21-2017, 08:23 PM
mattkosem's Avatar
mattkosem
mattkosem is offline
I've got an F56 that will soon be rolling on non-RFT summer tires, like my last two MINIs, and I've got the following bits on hand to deal with possible issues while motoring.
SLIME 40001 Pump SLIME 40001 Pump
16oz SLIME Bottle 16oz SLIME Bottle
Black Jack BLJK20SC Kit Black Jack BLJK20SC Kit
(with a set of pliers fitted inside the box)
Cartman Telescoping Lug Wrench Cartman Telescoping Lug Wrench
Light-Duty Jumper Cables Light-Duty Jumper Cables
MINI Jack
I'm hoping this setup should get me through most situations that an RFT tire would manage to survive (ie. most anything but a slash from large debris). Is this along the lines of what others are running? Weight and size were big factors in the setup I have, so my road kit is still probably under 10lbs. I'm curious what other people are bringing along, and if anyone else has taken it further or has good advise on what you've found handy to have on-hand.
--Matt
Old 02-21-2017, 08:37 PM
ayypeeemm's Avatar
ayypeeemm
ayypeeemm is offline
Amazon Amazon
Slime power repair kit.
That's all I have. Fits perfectly behind my pass side seat.
Old 02-21-2017, 09:39 PM
Fly'n Brick's Avatar
Fly'n Brick
Fly'n Brick is offline
https://www.griotsgarage.com/product...fType=&from=fn The bag also has enough room for an extra qt of oil, a shop rag or two and some quick cleaning/detailing supplies and a carefully packed jug of 'refreshment'.
Old 02-22-2017, 06:04 AM
02fanatic's Avatar
02fanatic
02fanatic is offline
That's the kit I have! Always fit snugly in the boot of my JCW. Hope I never need it though...lol!
Old 02-22-2017, 07:18 PM
mattkosem's Avatar
mattkosem
"refreshment"?
I need to put my stuff together in a way that takes up less space, but it's small and light so at least there's that
--Matt
Old 02-23-2017, 06:24 AM
buzzsaw's Avatar
buzzsaw
buzzsaw is offline
I too relied on all the tire kit fixings until a valve stem failed and the fixings were of no use. So I traded some room in the boot for some additional peace of mind and bought a donut spare. No worries now.
Old 02-23-2017, 12:39 PM
mattkosem's Avatar
mattkosem
Carrying a valve stem puller and spare cores isn't a bad idea. The slime bottle cap is a viable puller, but without stem cores you couldn't fix that problem.
--Matt
Old 02-25-2017, 11:41 AM
mattkosem's Avatar
mattkosem
Here's what I carry.
Old 05-19-2017, 06:27 PM
BUGETER's Avatar
BUGETER
BUGETER is offline
Slime kit
Old 05-19-2017, 07:52 PM
MIminiclubman's Avatar
MIminiclubman
MIminiclubman is offline
Slime kit. My Clubman and Countryman I have put it under the rear area floor. In my new PHEV model I have no clue I think the area I have used maybe taken up with electric car stuff. I also don't know how much room under the power seats. I am sure I will find a spot. I have Falkins on now and they have been great.
Old 05-20-2017, 12:32 AM
squawSkiBum's Avatar
squawSkiBum
squawSkiBum is offline
Moderator
Dynaplug kit and a Viair 85 compressor. It sat in the back for 40K miles until last Tuesday when I got a big screw through the tread in the parking lot at work. It took 4 plugs to seal it, no way a slime kit would have worked.
Old 05-23-2017, 10:24 PM
renchjeep's Avatar
renchjeep
renchjeep is offline
I carry a MINI Mobility Kit, and a few plugs, as well as the 2 tools needed for cleaning the hole and placing the plugs. I may just add a small tube of rubber cement at some point. This should get me through all but a sidewall puncture, or a catastrophic tire failure. I also carry a AAA card, with unlimited mileage. Just in case.....
Old 05-24-2017, 05:49 AM
cristo's Avatar
cristo
cristo is offline
Alliance Member
Dynaplug + manual pump.
+ compact spare ( have an R50).
Old 05-24-2017, 07:59 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
-=gRaY rAvEn=- is offline
Moderator
Word of warning with Slime kits as I used to carry one until I performed a rear seat delete and added a full size Enkie wheel/spare. ( not practical for most )
It may not be good to leave these kits in the MINI when temps drop to below freezing. It effected the contents of the Slime bottle I carried adversely, to point of not knowing whether or not it would work anymore. ( It was in my MINI for 5 yrs )
I tossed the whole thing in the trash, but maybe someone who has a kit can see if there are any warnings to that effect on the bottle or mfg directions.
Old 06-02-2017, 09:43 AM
newman4333's Avatar
newman4333
newman4333 is offline
I personally will never use fix a flat type stuff. I've seen what it does to rims. I'm not familiar with the slime stuff mentioned above so it may be better than the older products. My JCW has the full jack kit in the boot so I'm going to pick up a donut. I carry towing insurance so until then I'll just have it towed to the tire shop. Plus my mini is my "fun car" so I typically don't travel very far from home in it.
Old 06-02-2017, 10:49 AM
1200K's Avatar
1200K
1200K is offline
My F54 came with run-flats, but I will be moving away from those eventually and thus ordered the OEM spare and jack kit with the vehicle. I've never had a vehicle without at least a donut spare, can't quite wrap my mind around going without.
Old 06-02-2017, 11:24 PM
squawSkiBum
Moderator
Going without? It's like going commando, at first it seems like a big deal but after a while it just seems natural.
On the other car, in 15 years and almost 300K miles I have never used the donut spare. On my MCS, after 5 years and almost 60K miles I finally had to get out the dynaplug kit and compressor. Only once in my life have I had a catastrophic problem, a 10mm allen wrench went all the way through the tire. No plug or slime kit was going to fix that. That's why I have the AAA card.
Old 06-03-2017, 06:54 AM
DneprDave's Avatar
DneprDave
DneprDave is offline
Like squawSkiBum, I have an AAA card.
Old 06-05-2017, 05:50 PM
bratling's Avatar
bratling
bratling is offline
Super Moderator
Old 06-05-2017, 06:04 PM
02fanatic's Avatar
02fanatic
If I replace the runflats, or rather "when" I replace them, I will carry a spare wheel/tire on trips with the rear seats down ala GP style! Not a fan of donuts! For around town if a flat happens I will call my wife to come get me & I'll go get the spare at home! No way I'll call AAA even if I had it! :-)
Old 07-06-2017, 11:29 AM
DudskieG's Avatar
DudskieG
DudskieG is offline
May I ask where did you put the donut spare tire? I have a run flats too, no spare, no jack. Thanks
Old 07-06-2017, 12:01 PM
1200K's Avatar
1200K
1200K is offline
Sure -- Because I ordered the spare with the car, the steel wheel and the associated jack and tools came installed in the storage area beneath the rear hatch floor. The wheel bolts to a mounting point there, with the other items secured in a styrofoam tray that drops inside the wheel. I don't know whether the same mounting hardware is present if no spare was included with the vehicle -- I suspect others can answer definitively on that...
Old 07-22-2017, 03:49 AM
sselvia's Avatar
sselvia
sselvia is offline
These look usefull and compact
This place http://www.dynaplug.com/
has some nice options for tire repair, and the videos make it appear to work well.
Old 07-24-2017, 07:27 PM
mattkosem's Avatar
mattkosem
NAPA has a really cool mushroom-style plug gun too, which apparently works awesome.
--Matt
Old 07-27-2017, 06:08 PM
'05Train's Avatar
'05Train
'05Train is offline
Slime kit.
