Camber ruining my tires!
Old Feb 12, 2005 | 10:49 AM
  #26
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
For more on cupping see
http://www.dunlopmotorcycle.com/infocenter_faq.asp?id=9
Cupping may be worse if the tire rides up and down from being out of balance, mis inflated, subject to hard braking or uneven road surfaces.
I have had many sets of tires for street, track and autocross use and none have had cupping.
From the bentley MINI service manual I found on page 320-22
Front camber -0.30 plus or minus .25 degrees
Rear camber -1.32 plus or minus .30 degrees
The other stock alignment parameters I posted were from my alignment shop.
I'm currently running-
Front camber -2.3 degrees
Front toe 1/16" out
Rear camber -1.6 degrees
Rear toe zero
works fine for street, autocross and track. no severe wear noted with frequent rotations (every 1000-2000 miles at least)
Old Feb 12, 2005 | 11:03 AM
  #27
Rick-Anderson's Avatar
Rick-Anderson
I just got a set of M7 springs and I am going to have Steve's Auto Clinic install them this coming Wednesday. He is also going to install a set of controll arms and do the alignment so that it is close to stock. I am pretty excited to see how it turns out since I have similar concerns about tire wear.
Old Feb 12, 2005 | 11:09 AM
  #28
minihune's Avatar
minihune
You should be fine. Get a print out of the final alignment specs.
Ask for the settings to be set to the stock range as this will give you the smoothest ride. You can also ask for the rear camber to be set to the most negative within the stock settings or roughly -1.6 degrees. Tire wear should be fine as long as you keep tire pressures up (not over) and balance your wheels as needed (due to wear and rim damage). Front camber cannot be adjusted but should be fine at roughly -0.5 degrees.
Old Feb 13, 2005 | 12:03 AM
  #29
maxmini's Avatar
maxmini
Steve has the factory settings program for his 4 wheel alignemnt system and will definatly set you up properly. If you want something other than those specs just let him know and you will get what you want.
Randy
M7 Tuning
www.M7Tuning.com
Old Feb 13, 2005 | 02:17 AM
  #30
Hyper Blue's Avatar
Hyper Blue
Originally Posted by sadales
If you still have questions post back. FYI, I am a mechanical engineer in the automotive industry and an avid autocrosser in my spare time. Suspension, tires and alignment means a lot to me and I've done quite a bit of research and follow-on experimentation of my own. The autocrossing and commute "allow" me to experience several sets of tires a year.
Scott
90SM
Indianapolis area
Scott,
This is off the topic, but I'm thinking of studying mechanical engineering and also going into the automotive industry. Could you tell me a little more about what you do as an automotive engineer? Where you studied? Who you work for? I would really appreciate any information or suggestions you can give me. Thank you.
((Hyper Blue))(((((((((((((((
Old Feb 13, 2005 | 04:23 AM
  #31
BaldBikerGuy's Avatar
BaldBikerGuy
added control arms
Added control arms to the rear...BIG difference!!!
Old Feb 13, 2005 | 05:40 AM
  #32
JeffS's Avatar
JeffS
Originally Posted by kenchan
>your toe is probably way out in the rear.
I think the rear toe needs to be adjusted too. :smile:
I certainly hope everyone knows an alignment is mandatory after any ride-height change. Camber has minimal effect on tires. Toe, on the other hand, has a drastic impact.
Old Feb 13, 2005 | 08:34 AM
  #33
gone_motoring's Avatar
gone_motoring
Originally Posted by gone_motoring
I'm currently up in Cincy getting my 10K maintenance, tire rotation and JCW airbox upgrade. The service person called yesterday to inform me that the rear tires have some cupping too. She also did claimed that this is somewhat normal due to the MINI's rear suspension. I haven't picked the car up yet, so I don't know how bad it will be, running these tires on the front now. More later.....
Evidentally not bad at all as I can't feel any extra road noise, and certainly could not visually see any cupping in the first place, so it must have been very subtle. So I'm a happy camper!
wesmc
R55 :: Clubman Talk (2008+)
Sep 28, 2015 12:07 PM
broncobuddha
Suspension
Sep 18, 2015 05:16 PM
jesterofatlas
Sep 4, 2015 11:23 PM
Ntety
Sep 2, 2015 08:39 PM
