New tire size question
Old Nov 6, 2014 | 07:00 PM
Firemedicsafd's Avatar
Firemedicsafd
I'm at the point of replacing the tires on my 11 clubman. It has 195/55/16 run flats. I found a set of nice velocity rims and 215/40/18 tires. Assuming the wheel fits because the ad says for a mini and the bolt pattern is the same, will the tires fit in the hole of my wheel wells?
Old Nov 6, 2014 | 09:59 PM
bjcarter2's Avatar
bjcarter2
That should work just fine but 18" low profile tires can be a rough ride.
If you're set on them, test fit them first as those tires are 3/4" wider and if the offset is too shallow, you could rub on the struts.
Here's a good tire conversion calculator to use.
http://www.tacomaworld.com/forum/tir...5r16-215-40r18
Old Nov 7, 2014 | 01:15 PM
Alex@tirerack's Avatar
Alex@tirerack
What is the width and offset on the wheels?
Old Nov 7, 2014 | 04:28 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Assuming you have stock suspension, That tire size is slightly taller than OEM for tire diameter at 24.7" and is no taller than the frequently used 215/45-17 tire size on 17x7" wheels.
So the answer is yes they will fit however Velocity wheels that are 4x100 bolt pattern have a more aggressive offset than OEM which puts the wheel poking out of the wheel well by about 10mm or more.
Example Velocity wheel-
VW-211 M 18x7.5" et38
Compared to OEM 16" wheel the new wheel is 2.7mm closer to the inner suspension and pokes out 22.7mm, the tire is also wider than OEM so clearance will be very close.
You can see for yourself-
http://www.willtheyfit.com/index.php...et2=38#content
With a lowered suspension it would rub.
Old Nov 9, 2014 | 08:05 PM
Firemedicsafd
thanks! looks lie I'm going to stay with OEM size since i haven't done anything to the mini yet. PLUS money is tight around my household.
kazyn
Oct 25, 2019 02:34 PM
col127
Aug 21, 2015 02:11 PM
Mini'mon
Aug 16, 2015 12:47 PM
Edgar78
Aug 15, 2015 05:33 AM
