center wheel cap removal
Aloha and welcome to NAM.
Is there a reason you wish to remove the centercaps?
For each stock wheel they vary a little in size and can be pushed out from the backside of the wheel. Each one is a plastic disc with a few prongs to hold the cap in place via pressure.
You can remove one more easily if the wheel is off the car since you can gain access from behind the cap that way. Just push. You might need a screwdriver to help pry it out gently.
Sorry I don't know the part number but there is tool (see attached).
You could probably fashion a puller from a wire coat hanger or raid the office supplies
dyeLucky
Aug 7, 2015 07:10 AM
