Official F56 Wheel Fitment Thread
Old 05-23-2017, 07:51 AM
one2three_us's Avatar
one2three_us
one2three_us is offline
Originally Posted by strat61caster
What do you mean by "it" the rpf1? The 225 tire? The bbk? Which model mini? **** is so nuanced with these cars it's unbelievable.
The set pictured above (17x7.5 w/ 225/45/17) was ordered from the tirerack website as fitting a '14 F56 Hardtop S, they arrived on the doorstep mounted and balanced and bolted right up. When I checked last night before posting their website still lists them as fitting this car.
Cheers!
strat61caster,
Mine is a 15'JCW with Brembo Brakes. So finding a light weight wheel in 17" is a major PITA. I can go 18" like MarcoPolo did, however, I won't have lots of tires options. I would like to use 17" R888R in for track days and 18" Indy 500 for daily
  #902
Old 05-23-2017, 08:28 AM
ECSTuning is online now
Received 1,966 Likes on 1,766 Posts
Originally Posted by one2three_us
Thank you MarcoPolo for reconfirm that IT WON'T FIT! I was going to order from ECS after spoke to one of their Rep couple days ago. I was going to order it this morning. You just save me whole bunch of headach. Thanks again!
Sorry Guys, it was an error on our site. Thanks for bringing this up as we fixed it. If you see something funky on our site you can always shoot me a PM.
one2three_us - Love that signature. Always check out the main News section of NAM when we post up sales. Milltek sale just finished but you can find items on sale by selecting your model and clicking the upper right-hand side tab for Sale or Clearance and pick up some good deals.
  #903
Old 05-23-2017, 09:32 AM
MarcoPolo's Avatar
MarcoPolo
MarcoPolo is offline
strat61caster,
Mine is a 15'JCW with Brembo Brakes. So finding a light weight wheel in 17" is a major PITA. I can go 18" like MarcoPolo did, however, I won't have lots of tires options. I would like to use R888R for track days and Indy 500 for daily
My daily setup is 18x8 enkei pf01 on Conti extreme DW 215/40.
My track setup is 17x7.5 rse05 (16.6lbs!) On r888r 215/45.
  #904
Old 05-24-2017, 06:57 AM
strat61caster's Avatar
strat61caster
strat61caster is offline
strat61caster,
That all makes perfect sense, I just couldn't tell if that's what Marco Polo was getting at, too many pronouns in that post.
  #905
Old 06-01-2017, 05:57 AM
miniuy's Avatar
miniuy
miniuy is offline
I'm on the way of moving to VOLCANO ROCKET 17x7 ET35 rims.
I like the black ones (but the Ferrari logo. It will be deleted, of course).
I can't find any MINI pic with these wheels
Anyone??
  #906
Old 06-01-2017, 06:04 AM
MiniF55's Avatar
MiniF55
MiniF55 is offline
Soooooo, anyone running 8.5 wide wheels?
  #907
Old 06-24-2017, 04:33 AM
pepsih's Avatar
pepsih
pepsih is offline
I need a quick answer please
so i have 17" MINI 500 Tentacle Spoke Wheels
7Jx17 ET54 i just destroyed one tire on a pothole
however i would like to know if it's a good idea to install
215/45ZR17 instead of the original 205/45r17
  #908
Old 06-24-2017, 05:24 AM
vetsvette's Avatar
vetsvette
vetsvette is offline
Moderator
I did just that a week after I got my car. I had the same wheels. Goodyear Eagle F1 Asymmetric A/S 217/45X17 just cleared the struts. Never had a problem before eventually going with different wheels.
  #909
Old 06-24-2017, 05:30 AM
pepsih's Avatar
pepsih
pepsih is offline
thanks i think i will go with
BFGOODRICH G-FORCE COMP-2 A/S
Size: 215/45ZR17 91W XL
shouldn't be a problem i guess
  #910
Old 07-24-2017, 10:32 PM
NunoFariaBMX's Avatar
NunoFariaBMX
NunoFariaBMX is offline
Hey everyone! I've been looking for new wheels for my f56 Cooper and I really like how the Team Dynamics 1.2 look. I'm thinking about getting these in 17x7 but I'm not really sure on what et should I get, either 38 or 45. I'm on stock brakes and I plan on lower my car with lowering springs. What's your thought on the et? I don't want the poking way too much.
  #911
Old 07-25-2017, 02:00 PM
one2three_us
I believe they only have the black 45ET in stock in US
  #912
Old 07-25-2017, 02:21 PM
Anyone??
Wow never seen those before.
  #913
Old 07-25-2017, 05:48 PM
NunoFariaBMX
I'm from Portugal so that's not a big deal haha
  #914
Old 07-26-2017, 01:48 PM
one2three_us
Lucky you. i will go for38ET for the look
  #915
Old 08-06-2017, 08:34 PM
djtomy's Avatar
djtomy
djtomy is offline
I cant decide on wheels for my "16 JCW... either rse10s
(I know Ill need spacers to clear the brakes for either sets)
Offset (E.T.): +45mm
PCD (Bolt Pattern): 5-112
Center Bore: 66.5mm
Weight: 18.5 lbs
or the
O.Z.
Leggera HLT
FRONT AND REAR:
Finish: Gloss Black Painted
Weight: 18.65 lbs.
Offset: 48mm
  #916
Old 08-07-2017, 06:38 AM
miniuy's Avatar
miniuy
miniuy is offline
Center Bore: 66.5mm
Weight: 18.5 lbs
or the
O.Z.
Leggera HLT
FRONT AND REAR:
Weight: 18.65 lbs.
Offset: 48mm
I like the first one.
It seems the bolts zone is more "aggressive" (IMHO).
But, as you know, you'll need spacers to clear the brakes for either sets, so you should check what set is more secure (+45 or +48) thinking in your wheel spacers options.
Sometimes, 3mm could be a the difference between great and bad.
Regards
  #917
Old 08-07-2017, 07:57 PM
jlb's Avatar
jlb
jlb is offline
Center Bore: 66.5mm
Weight: 18.5 lbs
or the
O.Z.
Leggera HLT
FRONT AND REAR:
Weight: 18.65 lbs.
Offset: 48mm
I am running the RSE10 in my '17 JCW F57 with 12.5 mm spacers in the front and 15mm spacers in the rear. I moved them over from my F56 S, where I did not have to run spacers at all, of course. Here are some pictures that I took earlier today.
  #918
Old 08-08-2017, 02:22 PM
djtomy's Avatar
djtomy
djtomy is offline
That looks great! That helps out a lot, thanks for the pics. I'm pretty sure the F57 is the same as the F56. I have 12mm & 15mm spacers on my stock cup wheels now. I wonder if that would be about the same look on my F56 JCW with my spacers. The good thing about the RSE 10s is there hub centric also. not like the OZ. so on top of the more expensive OZ wheels I'm looking at Hub rings, and different spacers another $300 over the RSE10s. did you buy new TPms or swap them over?
  #919
Old 08-08-2017, 04:57 PM
jlb's Avatar
jlb
jlb is offline
You're welcome! F56 and F57 are the same (hard top vs convertible). I bought new TPMS's as I wanted to have 2 sets of wheels. The cups are 54mm offset, minus 12mm for your spacers.. so you are at 42mm . The RSE10 are 45mm minus the 12mm for your spacers... so that puts you at 33mm. So they are going to move out 9mm from your current set up. I am running 215/40/18 Michelin Pilot Sports A/S 3+ and my speedo is dead on when compared to the GPS.
  #920
Old 08-16-2017, 05:48 PM
djtomy's Avatar
djtomy
djtomy is offline
Center Bore size for Leggera HLT
I cant figure out the CB size on the O.Z. wheels to spec my center rings for my F56 66.5mm on the mini side
Leggera HLT
[/B]FRONT AND REAR:
Weight: 18.65 lbs.
Offset: 48mm
  #921
Old 08-17-2017, 01:11 AM
johntotah94's Avatar
johntotah94
johntotah94 is offline
Are your wheels platinum gray or matte silver?
Originally Posted by ryanschram
A mild drop looks great. this is on cravenspeed springs.
  #922
Old 08-17-2017, 07:44 AM
ryanschram's Avatar
ryanschram
ryanschram is offline
Platinum Gray
  #923
Old 08-17-2017, 01:17 PM
02fanatic's Avatar
02fanatic
02fanatic is offline
Platinum Gray
Nice presentation! I like the platinum wheels as black wheels, while fine on some colors, just seem to blend in with the black vinyl fender trim pieces to make the overall look awkward imo! The platinum is a nice contrast while still subtle. Great looking MINI!
Cheers
ryanschram (08-20-2017)
  #924
Old 08-22-2017, 07:13 PM
djtomy's Avatar
djtomy
djtomy is offline
test fitting wheels today with a 10mm spacer up front on a F56 JCW
the wheels are OZ Legerra HLT 18x8 +48 & probably 215/40/18 tires
Looks like I have a few mm to spare (guessing 5.5mm )between the brakes, So I will try a 8mm next. 5mm would be really close, 6mm would probably work, but, really2x3mm spacers..?
  #925
Old 08-25-2017, 01:54 PM
djtomy's Avatar
djtomy
djtomy is offline
So, Tirerack* wont sell me the rest of my wheels and tires in a package, (I have one wheel for test fitment)because they feel the O.Z. wheels need special lugs to fit there ball seat Legerra HLT wheels, vs Cone (radius vs 60* conical) mini's are Cone (oem)
Does anyone know of someone that will work with me at tirerack? I've been through 3 sales people already, the last guy said he wont write the order for safety issues.
SO they say... they don't make lugs in M14 x 1.25 ball seat.
So I said I would get studs or the suds that are 1.25 into the hub and either 1.25 or 1.5 stem, well they say they don't make nuts that are radius (ball) in either 1.25 or 1.5, that are small enough to fit inside the wheels..
So, I need advice NAM peeps, I bought the cone to ball adapter rings as seen below, but they said it wont work because there 14mm and I need 13mm or vice versa...
Does anyone else have an O.Z. wheel setup?
60* (Conical) Taper to Ball (radius) adaptors below V
Quick Reply: Official F56 Wheel Fitment Thread
