Accu-Torq vs Torque Wrench
Old Jun 7, 2004 | 10:12 PM
  #26
zgokart's Avatar
zgokart
Originally Posted by Trippy
I got my used Snap-on "digital" torque wrench in an Las Vegas pawn shop for $35 US. It was marked $99 and I offered $25 to start.
It was a great deal, and I would recommend that people visit their local pawn shops frequently.
Offer about 25% of the asking price with cash in your hand when you offer.
Expect to get called bad names, but then go up a bit and things get better.
I have paid between 25% and 50% of the asking price for everything I have gotten over the years.
__________________--
Thanks for the tip, Trippy. I guess I'll have to stop by at some pawnshops from now on. But no, my watch is not to be pawned.
Old Jun 7, 2004 | 11:03 PM
  #27
flyboy2160's Avatar
flyboy2160
wheel nut torque method works like a charm
with the wheel off the ground, tighten to 30to 40 ft lbs. just holding the wheel by hand.
lower the tire until it contacts the ground, but is not fully weight bearing. using the friction of the ground to hold the tire, tighten to full torque.:smile:
flyboy2160
Old Dec 13, 2004 | 08:28 PM
  #28
Skottoman's Avatar
Skottoman
I just looked at my Sears torque wrench and it only goes to 80 ft lbs. what do I do to put my lugs on? go to 80 and then snug it a little more with an x lug wrench?
I bought the wrench for rebuilding my motorcycle engine and it worked fine.
Old Dec 14, 2004 | 09:44 AM
  #29
jwardell's Avatar
jwardell
I have the same generic torque wrench that is identical to the $30 one at tirerack and $20 one at harborfrieght. I got it for $25 in discount hardware store. It's worked for years without trouble. I'm sure it's not of the highest quality, but most of us can't afford the hundreds for a good torque wrench, and it only gets used once in a long while when changing wheels or oil etc. So I would recommend it.
Old Dec 14, 2004 | 10:16 AM
  #30
GordonD's Avatar
GordonD
Originally Posted by pacostudio
I was looking at TireRack's 30$usd model. Do you know of any other place I should look at ? What would you think of that 30$ TireRack Torque Wrench ? :smile:I was just told to torque until it was f***ing tight so I would not lose a wheel
Thanks,
paco
I bought this and twisted the head off the 1/2" adapter pretty quickly. The wrench itself seems to be fine and i bought a better adaptor. I have an airgun for removal but I use a spider for putting them on and the torque wrench for final tightening -never use the air gun or you might never get them off if you have a roadside flat.
Everything I've been taught at track days says torque evenly to 85 ft lbs so that's what i do.
MGBill1186
Oct 2, 2015 06:54 AM
pkillur
Sep 30, 2015 10:51 AM
EVMini
Sep 28, 2015 10:20 AM
Nicefeet
Sep 27, 2015 11:14 AM
Sep 25, 2015 12:32 PM
