Air Leak Question
Old Nov 18, 2012 | 06:48 PM
amagicfro's Avatar
amagicfro
Hi All,
I recently swapped out tires on my '11 Justa from the stock Conti Run Flats to Bridgestone Potenza. I went from 195/55/16 to 205/55/16.
I bought the tires from tirerack and had them mounted at one of their reputable installers.
They were installed yesterday. I was driving around today and the low tire light came on. I checked the PSI and it was at 15! (recommended PSI is 33)
I filled it back up at a gas station, hoping it was a fluke. When I got home 2 hours later, it lost 2 PSI.
My question is, should I contact MINI about the possible air leak or take it back to the tire installer? I'm still covered by the MINI warranty until 2014. I was curious if I had my own tires mounted it would negate the warranty coverage.
Thanks!
e: tires were installed yesterday.
Old Nov 18, 2012 | 06:59 PM
Eric_Rowland's Avatar
Eric_Rowland
Go back to the installer. Likely a leak in the TPMS, or a bad seal at the bead.
Old Nov 19, 2012 | 04:57 AM
ZippyNH's Avatar
ZippyNH
+1
should be a simple fix...they should remount the tire after cleaning the rim to get a good seal, and maybe change a gasket on the valve......
Old Nov 19, 2012 | 10:46 AM
amagicfro's Avatar
amagicfro
Update for everyone.
Apparently I rolled over a drywall screw without realizing it. It didn't punctured the tread luckily. I don't why but it leaked pretty slow. It was dead center on the tread area, so I didn't catch it right away.
Took it back to my tire installer and had it patched.
Still mad about catching a screw on brand new tires. Suppose it could have been worst.
twistedimages
Sep 19, 2024 04:13 AM
W0TM8
Dec 19, 2019 07:50 AM
polotska
Aug 23, 2015 09:10 AM
damncajun
Aug 17, 2015 08:25 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
