Snow chains on a Mini Cooper S w/ 17" wheels
Old Sep 25, 2012 | 07:50 PM
Aloisius's Avatar
Aloisius
Hello all,
I have a 2013 Cooper S coming and it'll be here right during the Tahoe snow season which means chains. The 2012 manual indicates that chains should only be used for wheel sizes up to 16", but my Mini is coming with 17" wheels.
I know Thule makes a couple low profile chains like the Thule K-Summit and there is that Spikes Spider company that also uses low profile chains.
Has anyone used any of these? Did they fit ok? Are there any others that might fit as well?
Old Sep 26, 2012 | 10:09 AM
rburna's Avatar
rburna
This doesn't exactly translate to the Mini, but I've installed cables (alternative to chains) on an Accord. which worked just as well. So I went out n bought a set of cables for my Mini. Haven't used them yet tho, but I they are adjustable and fit many tire sizes. As with most chains and cables, they are dependent on your tire size, just check the box when you get some.
Chains, cables, both are still difficult to put on. Chains are just heavier and might make the install a bit tougher.
oh and when removing the cables, make sure to put them away as you unpacked them otherwise they get tangled
Old Sep 26, 2012 | 10:28 AM
Kahnfucious's Avatar
Kahnfucious
EDIT: I was wrong http://www.tahoe.com/2012/01/26/lake...-requirements/
I have heard stories of them ONLY allowing 4 wheel drives WITH chains when the snow gets heavy enough though.
I am not sure if chains will work that well or if I would feel comfortable using them on a MINI with the chance of throwing one against the car and damaging it horribly...but then again I have only used chains once.
Old Sep 26, 2012 | 02:33 PM
Aloisius's Avatar
Aloisius
I suppose I could put 16" snow tires on it and then have more room for normal-sized chains for the winter.
TREX
Nov 2, 2019 07:31 PM
SosoMINI
Nov 22, 2015 03:17 PM
Mini'mon
Aug 16, 2015 04:15 PM
nomar116
Aug 12, 2015 05:24 PM
