Painting Wheels - Balance?
I plasti diped my wheels with many, many coats and I had zero problems with balance. I think changing your plastic valve cover for a metal one would mess with the balance more than painting the wheels.
Depends on what is acceptable to you as a paint job. A first class job would require removing the tires, wheel weights and valve stems, so of course you would have to re-balance. If you are just spraying the outer face and don't have any weights there and are OK with masking off the stems, then there would be no need for re-balancing.
Spank
11
Apr 9, 2020 02:23 PM
thebordella
Aug 31, 2015 01:37 PM
O4mcs
Aug 6, 2015 05:42 AM
