Offset (ET) 35 16 inch will it fit
Old Aug 7, 2012 | 10:38 PM
SODA66's Avatar
SODA66
I have a chance to buy some 16 inch wheels for my 2011 cooper that have 35 offset. Currently I have the 17 inch Mini lites with 205/50/17 which I do not like. I think the 16 inch wheels fit my needs better.
QUESTION: HOW WILL THE 16 INCH 35 OFFSET LOOK ON MY CAR. WHAT ARE MY LIMITS ON 16 INCH TIRES,SO THE WHEELS DO NOT STICK OUT PAST THE CAR.
THKS
Old Aug 8, 2012 | 09:36 AM
Alex@tirerack's Avatar
Alex@tirerack
ET35 will be right at the edge of the fender in most cases. What width wheel? 205/50R16
Old Aug 9, 2012 | 09:19 AM
SODA66's Avatar
SODA66
I was thinking about 195/50/16. Also the wheels are 7 inches wide.
thks
Old Aug 9, 2012 | 10:05 AM
C4RACER's Avatar
C4RACER
thks
OEM 16's come with 195-55-16 tires btw.
We have a 03 Mazda Protege5 that came with a 195-50-16 tire originally. I found that to be a bit undersized for the car and also very few tires are available in that size. So I've been running 205-50-16 ever since the first set of tires purchased, and it's been thru quite a few sets with over 150K miles at this point! I that is a 6" wide rim.
For a 6.5-7" rim I would for sure go with a 205-50-16 on a Mini. That's also much closer to the OEM diamater of either the 205-45-17 or the 195-55-16.
Old Aug 9, 2012 | 06:10 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
thks
Compared to stock 16" wheels and tires-
16x7 with offset 35mm should be OK
the wheel and tire will stick out 18mm or 0.7" wider than stock which should be fine.
Use 205/50-16 or 205/55-16 tire if using stock suspension.
195/50-16 could be used but it is smaller than stock tire diameter so it would increase wheel gap.
SosoMINI
Nov 22, 2015 03:17 PM
madmax88
Oct 26, 2015 01:45 PM
jwildr56
Aug 26, 2015 12:40 PM
TJANK
Aug 24, 2015 06:11 PM
Mini'mon
Aug 16, 2015 04:15 PM
