Help turning off brake pad warning light
Old Jul 18, 2012 | 08:59 AM
Themajickman's Avatar
Themajickman
I scanned this forum and I couldn't find an answer so hopefully I can find an answer to my problem.
The warning light came on saying that our Brake pads needed changing. My son proceeded to replace the pads, rotors and sensors. I thought that once the sensors were replaced that the warning light on the dash would go out but no, unfortunately it still lit up. Can anybody tell me how to reset it or is there possibly still a problem?
Old Jul 18, 2012 | 09:46 AM
jcauseyfd's Avatar
jcauseyfd
Try one of the two methods in this document. hth.
Old Jul 18, 2012 | 10:02 AM
Themajickman
I appreciate the information. I'll give it to my son and hopefully it will work even though it appears to be for a 2008-Gen2 Mini and ours is a 2007 R52 convertible S GEN 1 (which I should've mentioned before)
Old Jul 18, 2012 | 10:08 AM
jcauseyfd's Avatar
jcauseyfd
My bad, I should have noticed that from your sig. Might be able to figure it out using the directions here.
Old Jul 18, 2012 | 10:13 AM
Themajickman
we'll give it a try. I forgot to look on the MINI2 forum for any information, thank you, Paul
Old Jul 18, 2012 | 03:01 PM
Themajickman
I found the solution! Turn the key to position 2 and leave it there for 30 seconds, the light will go out, and then you start the vehicle. Pretty simple solution. Thanks for our your help
W0TM8
Dec 19, 2019 07:50 AM
JamJam43087
Aug 16, 2015 02:02 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
