Brake bleeding on '05 justa - Bentley instructions
Old May 11, 2012 | 10:40 AM
Omicron Pie's Avatar
Omicron Pie
Hello,
After a year or so of use, it's time to do some brake work. So as not to work in the dark or bother ths forum for every little detail, I first obtained a Bentley's manual. And still have questions!
On brake bleeding, step one in the manual is
1. connect factory scan tool & call up service function Bleeding....
2. connect pressure bleeder
3. starting at right rear wheel, connect bleed hose, open bleed valve and flush until clear, then close bleed valve - repeat for each wheel.
And you'd think you'd be done at that point. But no, then comes step 4:
4. starting at right front this time, connect bleed hose, open bleed valve and this time pump brake pedal at least a dozen time until clear, then close bleed valve with pedal held down- repeat for each wheel.
Which leads me to a couple of questions:
a) Factory scan tool and pressure bleeder? Are they serious? So, are they eseentially aying it is humanly impossible to bleed the brakes without a factory scan tool?
b) It sounds to me that we just bled the brakes twice. No?
Thanks.
Old May 15, 2012 | 05:34 PM
Omicron Pie
OK, maybe I needed to phrase differently -
Who's bled their brakes and did you use a factory scan tool to actuate the ABS and if not did it turn out alright?
Thanks.
Old May 15, 2012 | 06:01 PM
miniconcarne's Avatar
miniconcarne
I've done 4 MCS first gens without a factory scan tool, can't imagine an R50 is that tool specific. It almost sounds like the insructions are for a complete flush, but still, I wouldn't think a scan tool is needed. Now bleeding the clutch slave can be a bear.
Old May 15, 2012 | 06:04 PM
miniconcarne
Here is a great how-to with a couple of methods: R50 bleed
Old May 15, 2012 | 08:30 PM
cct1's Avatar
cct1
I have an R53, I've bleed the brakes more times than I can count, and not once used a scan tool. I use a pressure bleeder, but those are cheap, although there's no reason you can do it without. Looks to me the Bentley manual is going the overkill route on this one.
Old May 16, 2012 | 07:18 AM
cristo's Avatar
cristo
Alliance Member
I'll bet that even the dealer doesn't hook up the scan tool unless they think there's air in the ABS unit.
Old May 17, 2012 | 05:05 AM
Omicron Pie
OK, thanks all.
squawSkiBum
Tires, Wheels, & Brakes
27
Nov 19, 2024 10:26 AM
Chasp
Sep 11, 2015 09:04 AM
FLYM1N1
Aug 15, 2015 04:39 PM
2manyhobbies
Aug 9, 2015 06:02 PM
