What size wheels for my 03' MCS??
I've been looking around for some new wheels that will replace my factory 17" wheels on my 03' MCS.
I'm assuming that something like a 17x7.5 or 18x7.5 will work? What about offset.....what should I go with? The car is a daily drive...it will never see the track, and I don't have any plans on lowering it.
The 17" wheels look good, but I think 18's look better...and they are not much more money. Is 7.5 about as wide as you want to go without having any rubbing issues?
Any suggestions?
Here is what it looks like now....
Any suggestions?
I had 17x7 on my 2003 MCS with 215/40 tires. I have 18x7 on my 2006 MCS with 215/40 tires. Both have been with 37 offset. My cars are lowered, 2003 1" and 2006 5/8" with slight rubbing on the outside rear on both cars.
If you go with 7.5 wide wheel the offset will need to be increased a little from the 7" to not rub but it also depends on what width tire you use.
I had 18x7 with 55 offset and 215/40 tires with no rubbing on the inside but it was a little close.
TireRack is a good one. Pick out your wheel that you want and what brand. If TireRack has it go for it they have a great track record among buyers, or shop it out on the WEB.
Mini'mon
Aug 16, 2015 04:15 PM
Rennfahrer555
Aug 13, 2015 09:07 AM
dyeLucky
Aug 7, 2015 07:10 AM
