18" on a R52
Old 11-29-2011, 06:07 PM
Mootsdog's Avatar
Mootsdog
Mootsdog is offline
18" on a R52
I have a chance to pick up 18's for my 06 R52 S stock suspension. Tires are 205 35 18. Rims are DIP 18x7.5. They are coming off a 2010 MCS. Any problems I should be aware of?
Old 11-30-2011, 03:04 PM
bluefox280's Avatar
bluefox280
bluefox280 is offline
What's the width, offset of the wheel and tire size of your current wheels?
What's the offset of the 18" wheels you snagged?
- Erik
Old 11-30-2011, 03:59 PM
Mootsdog's Avatar
Mootsdog
Mootsdog is offline
The wheels and tires I have now are my winter set. Stock S-Lites 7" wide with Pirelli 240 non rft. 205 45 17. Offset is +48mm. The new ones are DIP D66 Slack 18 x 7.5 with +40mm offset.
Old 12-01-2011, 07:32 AM
bluefox280's Avatar
bluefox280
Going from a 17x7 @ 48mm offset, to a 18x7.5 @ 40mm offset will push the wheel position out 14mm and provide 2mm less clearance on the inside.
The 205/35-R18 tires are smaller overall diameter, therefore your speedometer will read 2.5% too fast (ex: speedo says 60mph, you're acutally going 58.5mph).
- Erik
Old 12-01-2011, 09:07 AM
Mootsdog's Avatar
Mootsdog
Mootsdog is offline
So in real math terms that means the tires will stick out about 1/2" and be about an 1/8" closer to the struts. I'm too old for this metric stuff. I have no plans on lowering the car. Do you see a problem doing this? I haven't bought them yet. They are on NAM marketplace under wheels and tires. He lives near me and is holding them til later on this month.
Old 12-01-2011, 10:10 AM
bluefox280's Avatar
bluefox280
Correct.
Nope; you're good.
- Erik
Old 12-01-2011, 11:30 AM
Bilbo-Baggins's Avatar
Bilbo-Baggins
Bilbo-Baggins is offline
I hope you realize that you will be getting a rougher ride. Also with all of the winter potholes you get in Albany you will have them bent in short order.
Old 12-01-2011, 12:54 PM
Mootsdog's Avatar
Mootsdog
Mootsdog is offline
Bilbo- No worries on my end. I have a nice set of s lites with pirelli snows for winter. These are for summer only. Albany potholes are more visible then.
Bluefox- Thanks for all the info. Will be picking up the rims and tires in a couple weeks.
10-01-2015 12:34 PM
10-01-2015 12:34 PM
10-01-2015 12:13 PM
Tires, Wheels & Brakes
10-01-2015 08:55 AM
09-30-2015 10:58 AM
Quick Reply: 18" on a R52
