Drove 1100 miles on a 100% flat run-flat tire! (Have a quest
Hey Guys! That's right I drove to two different places without knowing my back right tire was 100% flat. I got an indicator light every time I drove the car but thought is was telling me there was a change in pressure b/c of the extreme temp. change. Anyway, I got it patched yesterday and want to know where can I get a Dunlop SP 9000 DSST tire for real cheap? I'm really impressed with this tire! According to Dunlop: Designed to continue running for up to 50 miles at speeds up to 55 mph even after sustaining air pressure losses which would render... I just proved you can go 1100 at 90MPH with no problem. Anyway, hope someone could help me out!
I hope someone can help you out...but I also hope you take life nice and easy for the next couple of months. I think you expended at least a couple of months of luck on that tire. 90 mph and over 1000 miles is WAAAAAY over the design tolerance. We're lucky you're still with us.
(ps - your theory about changing pressures due to low temp and THAT causing the light to come on doesn't make a whole lot of sense. If one tire is changing pressure that way, you should STILL check it out. And besides, why would just ONE tire change pressure due to cold?)
Powershift
Aug 16, 2015 05:14 PM
