Will these studs work?
Old Sep 23, 2011 | 11:32 AM
MrV's Avatar
MrV
Anybody know if these studs:
http://www.race-studs.com/servlet/th...ce-Stud/Detail
or
and these lug nuts:
http://www.race-studs.com/servlet/th...ardened/Detail
will work on an R53 Mini?
Looking to use them with a variety of wheels, but mostly my Enkei street wheels and some Rota Slipstreams, but it's conceivable that stock wheels would go on as well. All of these wheels currently fit using the OEM bolts.
EDIT: Oh yeah, and any reason to NOT go with the longer studs? I kind of like the look, and it appears as if the shorter ones don't have the hex bolt input on the end.
Thanks all.
Old Sep 23, 2011 | 12:00 PM
bluefox280's Avatar
bluefox280
Yes, those lug studs in M12x1.5 are direct fit to the R50 / R53 platform.
How long are you OEM lug bolts? If the stud is longer (that mounts the wheels, not to the hub) is the same length or longer, it'll work.
Extra length is up to you and appearance / application preference.
- Erik
Old Sep 23, 2011 | 12:18 PM
MrV's Avatar
MrV
Thanks - so the lug nuts are correct too? "60 degree conical nuts".
They look identical to the TSW stud / lug set (but cheaper!)
$19.20 for lugs
$68.00 for studs (cheaper if you get the shorter ones)
$87.20 Total
vs. $120 for the TSW kit.
ebowling
90
Aug 4, 2019 09:15 AM
MINI VINI
Oct 13, 2015 08:57 AM
rckrzy1
Aug 26, 2015 09:12 AM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
minipopkart
Aug 13, 2015 05:22 AM
