Help! with passenger rear brake caliper
Old Aug 23, 2011 | 08:34 AM
cjgo's Avatar
cjgo
I have put new pads all around my 2005 Mini. No problems until I got to the passenger rear caliper. I have the compression tool that you turn but it will not go back in. Any suggestions would be appreciated. I have applied pressure and turned. Been trying for over an hour to get this caliper compressed!!!
Finally got it!
Old Aug 23, 2011 | 10:01 AM
BRGPA's Avatar
BRGPA
When you spin the tool do the prongs spin, too? They should. If they don't, like my Harbor Freight one did, you need to put a pin of some sort like a nail or cotter through the hole in the threaded shaft so it all rotates as a unit when you twist the handle. Some solid pressure will also be needed to make the pads retract and spin. Good luck!
Old Aug 24, 2011 | 07:10 AM
ofioliti's Avatar
ofioliti
Good you got it resolved.
In case others with the same problem come across this thread, a c-clamp and pliers worked for me:
https://www.northamericanmotoring.co...ating-why.html
W0TM8
Dec 19, 2019 07:50 AM
jpgwinn24
R55 :: Clubman Talk (2008+)
Aug 20, 2015 06:57 PM
StealthR53
Aug 8, 2015 10:59 AM
