:: NEW ARRIVAL 17x8 17x9 LM ESM-004 NOW AVAILABLE ALL BOLT PATTERNS AVAILABLE!:: [IMG
Hey Guys and Gals!
Ill get right on to the info here since im to excited about these wheels
We have had a huge demand on our ESM-004 in 17" so we went ahead and designed the wheels in 17x8 and 17x9 in all bolt patterns!
MIN Cooper SPECIAL FOR A LIMITED TIME ONLY!!!!
We will be offering -15% OFF On all our wheels for a limited time!!!
USES PROMO CODE: MINI13
17x8 all around
17x8 and 17x9 staggered
Her is a link to the site:http://esmwheels.com/access/wheels-e...cPath=21_56_57
Wheel Specification(s):
Approximate Wheel Weights: 17x8 = 21lbs. / 17x9 = 22lbs.
Size Bolt Pattern Offset Center Bore Lip Size MSRP $ (USD) In Stock
» 17x8 4x98 38 67.1 1.5" $175/wheel Yes
» 17x8 4x100 35 57.1 1.5" $175/wheel Yes
» 17x8 4x100 20 57.1 1.5" $175/wheel Yes
» 17x8 4x108 38 67.1 1.5" $175/wheel Yes
» 17x8 4x114.3 35 67.1 1.5" $175/wheel Yes
» 17x8 5x98 38 67.1 1.5" $175/wheel Yes
» 17x8 5x108 38 67.1 1.5" $175/wheel Yes
» 17x8 5x100 35 57.1 1.5" $175/wheel Yes
» 17x8 5x100 20 57.1 1.5" $175/wheel Yes
» 17x8 5x112 32 66.6 1.5" $175/wheel Yes
» 17x8 5x114.3 35 73.1 1.5" $175/wheel Yes
» 17x8 5x120 38 72.6 1.5" $175/wheel Yes
» 17x8 5x120 20 72.6 1.5" $175/wheel Yes
» 17x9 4x100 40 57.1 3.0" $225/wheel Yes
» 17x9 4x100 25 57.1 3.0" $225/wheel Yes
» 17x9 4x114.3 40 67.1 3.0" $225/wheel Yes
» 17x9 5x100 25 57.1 3.0" $225/wheel Yes
» 17x9 5x100 38 57.1 3.0" $225/wheel Yes
» 17x9 5x112 40 66.6 3.0" $225/wheel Yes
» 17x9 5x114.3 40 73.1 3.0" $225/wheel Yes
» 17x9 5x120 40 72.6 3.0" $225/wheel Yes
» 17x9 5x120 25 72.6 3.0" $225/wheel Yes
Her is a pix of the 17x9" We will have more pixs up by Monday:peace:
The wheels can be painted. The wheel rivets pop out for painting
Thanks I just mounted a set on my M3 and im in love!
WANT!Any pics of the 17x8 +35s? How much do the 17x8s weigh?
This is probably the most aggressive size MINI guys can run (with 235/40s) without stretching sidewalls ... My plan is to pair these with a set of Toyo R1Rs for next summer.
All the specs are listed on the site at www.esmwheels.com . If you would like to use a bigger tire size the higher et is the best option for you
Please contact us for further info...
Thanks,
Please contact us for further info...Thanks,
Got my order in
Just ordered a set, 17x8 et35. I will post pictures for you when they come. I am thinking from other posts that 215/40/17 will work good. Anyone have tire experience in this area with this size and offset? Thanks.
No rubbing at all so far, but the car is not lowered yet. The install guy was surprised at how much lighter this wheel/tire combo is than the stock ones. Those stock wheels are HEAVY.
There is a guy on here by the name of Rally@StanceDesign who knows lowering mini's and wheel/tire fitment like no other. I read tons of his posts on here and over at motoring underground to find my fitment. He could tell you if those tires would fit. I think they would be difficult as there is not a ton of space on the inside of the wheel when you go wider, they hit on the inside. I'll try to get some better pictures up today of the car and wheels.
That really does set off the look of the car nicely. Pure class.
If I recall, S-Lites are in the neighborhood of 28 lbs per wheel. They look good (they belong on a very short list of factory wheels which [I think] truly belong on a car), but they're too narrow and too heavy.
Thanks and have a great day,
You should go to 215's if you are buying new tires anyway. I have not had any rubbing at all with mine and 215's are wider than stock 205's. Handling is better with the wide tires.
I may paint the centers a different color as well.
