205/50R17 on S Lites
Old Jul 11, 2011 | 07:29 AM
madmaxxed's Avatar
madmaxxed
So back to the drawing board for new snow shoes. Found another great deal on a set of Bridgestone Blizzaks only used for one season.
should these work out ok with my stock S Lites? 205/50R17
Thanks!
Old Jul 11, 2011 | 07:39 AM
JAB 67's Avatar
JAB 67
Thats not really the direction you want to go for snow tires. Try to find a set of 15" wheels, then put on 185/65-15.
Old Jul 11, 2011 | 07:44 AM
madmaxxed's Avatar
madmaxxed
the direction i'm going in is low budget. My stock wheels are sitting in my shed not being used. I'd rather use them and pick up a set of cheap tires for winter use. i'm trying to avoid buying a package that will cost more than i want to spend.
Old Jul 11, 2011 | 08:09 AM
Blackbomber's Avatar
Blackbomber
The 205/50/17 is going to be 8/10ths of an inch taller overall. This will raise your car by half an inch (good), but will also fill the wheelwell by the same amount (not necessarily so good). Plenty of people are running 215/45/17's, which are 3/10" taller, not to mention 10mm wider on cars lowered an inch or so Therefore it's my suspicion that they should be fine. Yes, a narrower tire would be preferred, but I also read of people running stock size snows that swear by them. For the right price, I'd go for it on a non-lowered car.
Old Jul 11, 2011 | 08:10 AM
Blackbomber
Oh, I forgot to mention that my diameter information in the above post comes from the tire size calculator on miata.net.
Old Jul 11, 2011 | 08:11 AM
madmaxxed's Avatar
madmaxxed
thanks for the response. I'm not lowered at all and have some wheel spacers on as well. not sure if i'll keep them on for winter use.
The price is right plus the guy isn't locked in at his list price which is even better!
Old Jul 11, 2011 | 08:59 AM
Porthos's Avatar
Porthos
Talk to Alex at tirerack he will help you and explain in pretty good depth on what is best for your MINI. I just bought my 2nd set of tires tonite and he helped me out a lot.
Kimolaoha
Dec 5, 2020 09:32 PM
ryGuyMCS
Oct 6, 2015 12:04 PM
vargasgal
Sep 17, 2015 10:02 AM
shahriar35
Sep 14, 2015 11:53 PM
