Slicks on stock differential
I bought some slicks and I plan to use them on the drag stip next saturday.
Do I have to worry about breaking the stock differential, I have no LSD at the moment?
Have anyone tried this, and does it have any advantage than running regular tires ?
What are your cars numbers roughly? If you are between stock hp and 200 or so then it shouldn't be a problem for your diff, a stock clutch may have a rough time if you are dropping from 4k repeatedly though
Well, I dont know my numbers yet, wheel hp or brake hp ?
I have 17% pulley, K&N and One-Ball mod.
My best ET is 14.501 @ 96.360mph which gives range from 190-210 flywheelhp
I would say that without a tune you would be running around 190-195 and if you got a decent tune you could get up to 205-210, those are pretty good times though good job! Just make sure you fully drop the clutch, you don't want to burn more than you have to!
Colt45Magnus
Aug 27, 2024 05:03 AM
