Nitrogen in run flats
Old Jun 2, 2011 | 09:42 AM
  #26
jonbettie's Avatar
jonbettie
I very much appreciate all of the responses but I'm a little sorry I brought the whole thing up.
Old Jun 2, 2011 | 09:58 AM
  #27
cristo's Avatar
cristo
Alliance Member
That's what usually happens with nitrogen in tires threads.
Same thing also usually happens on audio forums with discussions on the merits of expensive cables (but much, much worse in that case).
Old Jun 2, 2011 | 10:09 AM
  #28
CAMOTOY's Avatar
CAMOTOY
i think its a good discussion. we are all civil here :D its like the discussion of how to break in your engine, either keep the rpms low, or flog the hell out of it :D
Old Jun 2, 2011 | 10:12 AM
  #29
jcauseyfd's Avatar
jcauseyfd
For an encore, you could ask a question about oil change intervals!
Enjoy your MINI!!!
Old Jun 2, 2011 | 10:55 AM
  #30
Miniblue2's Avatar
Miniblue2
How long do I have to wait for all the oxygen to seep out so I have just nitrogen. With the run flats I can still motor.
Bill
Old Jun 2, 2011 | 12:58 PM
  #31
coldnorth's Avatar
coldnorth
Originally Posted by el_Zilcho
Just out of curiosity, since I am certainly NOT an expert on transport phenomena, do you know roughly what that difference in permeability is?
Curious because by increasing the concentration of nitrogen in the tire vs the outside air, wouldn't you be increasing the permeation rate of N2 out of the tire?
Assuming 49.7 psia in the tire and 14.7 psia atm., 79% N2 in air:
With air you are at a N2 partial pressure of 39.3 inside the tire, 11.6 outside the tire, so a difference of 27.7
With 100% N2, you are at a n2 partial pressure of 49.7 psi inside, 11.6 outside, so a difference of 38.1, or about 37% higher than air. So I would assume the permeability of O2 vs N2 in rubber has to be quite a bit higher?
Also interesting on the CR study. Would be good to know if they were using dry air as a comparison. Funny tire manufacturers did not think nitrogen was necessary. Not sure a 1.3 psi difference in a year is significant enough for me to worry about anyway
I don't know the exact numbers but the consumer reports data shows only a small difference. I am somewhat skeptical of the control data since my personal experience is that tires lose air faster than they reported. The effect of air on tire liners is interesting to me, especially if you keep your tires for many years (low mileage driver). The exposed rubber is protected with heavy doses of antioxidants/UV protectants but I am not sure the add anything to the liner compound because it doesn't see sunlight.
Personally if it's not too expensive I will switch to nitrogen because I don't see any down side.
CN
Old Jun 2, 2011 | 01:48 PM
  #32
JudgeS's Avatar
JudgeS
CN
Yea if it doesn't cost you anything there is no point not to, I'm going to check if the costco by me has free N2.
Old Jun 4, 2011 | 05:35 AM
  #33
MiamiGuitarMan's Avatar
MiamiGuitarMan
Unless you're getting your tires filled in a vacuum, there's no way you're going to have 100% nitrogen in them. Even a flat tire will still have a substantial amount of regular air in it.
And as many have mentioned, the air we breathe is already 78% nitrogen.
I think that any place that charges for nitrogen is ripping off their customers unless they have some kind of a vacuum they put the tires in before filling them with nitrogen.
But if it's free, like it seems to be for a few of you, go for it. I wouldn't pay anything for it though.
Old Jun 6, 2011 | 05:49 AM
  #34
Flyer53's Avatar
Flyer53
I will be mounting the new NE Eng. 19" Countryman wheels soon as the tires come in Tues/Wed. of this week. I have the original 17" tunnel spoke (anthracite) wheels with the run flat all seasons straight from the build, for sale next week if any one is interested..Approx 4650 current miles, excellent shape..View them in my gallery...PM me
khumpert
Nov 30, 2015 11:48 AM
Dieseldoctor
R55 :: Clubman Talk (2008+)
12
Sep 10, 2015 04:48 PM
ltjpunk7
Sep 6, 2015 07:32 AM
TJANK
Aug 24, 2015 06:11 PM
jziran
Aug 24, 2015 04:50 PM
