I dropped down to 36psi in my non-runflats
Old Jul 18, 2010 | 07:28 PM
ronnie948's Avatar
ronnie948
I now have Michelin Exalta PE'2 215/45/17 non-runflats in place of the Dunlap 205/45/17's run-flats that came on my JCW.
I went to 36psi instead of 38psi. I think I could really go to 34psi looking at the footprint that the tire puts down.
What pressure is everybody that runs 215/45/17 non-runflats using? I'm sure that 38psi will wear out the center tread way before the edges by looking at the footprint the tires make.
Old Jul 19, 2010 | 04:26 AM
Crashton's Avatar
Crashton
If you are using MINIs recommended pressures they are for runflats. As you know those tires are constructed very differently. That pressure could be a place to start, but as you've discovered you can get by with less pressure in a normal tire. Keep an eye on the wear patterns & drop it some more. I'm running 30 in my Goodyear GSD F1, but they are a different tire & different size. As they say your mileage may vary.
Old Jul 19, 2010 | 04:58 AM
Speedwing's Avatar
Speedwing
34 psi in the fronts and 32 psi in the rears has worked well for me. Tire pressure is very subjective based on how much of a load the tire was designed for ... and how you have it loaded.
Old Jul 19, 2010 | 11:41 AM
martinb's Avatar
martinb
215/40-18's. Hankook Ventus V12 Evo's. 38 front, 36 rear. Handles superb and sticks like glue.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
navybsn
Oct 4, 2015 03:27 PM
aldito2
Sep 30, 2015 10:44 AM
Samhillrocks
Sep 29, 2015 12:55 PM
gnhovis
Sep 28, 2015 10:56 AM
