Attn Alex: Mach V springs and Koni FSD's
Old Apr 23, 2010 | 08:18 AM
sbarton's Avatar
sbarton
I'm looking for some struts. I have Mach V springs and stock struts. The car is my daily driver, but does see the occasional spirited action.
I'd like some struts that soak up the bumps and harshness better but don't want to sacrifice the handling. Right now I cringe every time I see a bump, pot hole, or expansion joint. I would not mind the Koni adjustables as I would moslty run them on soft, and then could switch to a firmer setting for autox or track use.
But if the Koni FSD's will give me what I am looking for w/o having to make adjustments for each type of driving situation and will work well with the Mach V springs I would rather go in that direction.
I saw on the Killer Koni sale thread that the FSD's are for stock springs only.
Will the FSD's work well with the Mach V springs?
How much of a difference are the Mach V springs over stock (height and stiffness differences)?
-Scott
Old Apr 23, 2010 | 09:21 AM
Alex@tirerack's Avatar
Alex@tirerack
FSD's work well with mild lowering springs like Eibach Pro kit .
How far does Mach V's kit lower?
Old Apr 23, 2010 | 09:34 AM
sbarton's Avatar
sbarton
http://www.fastmini.net/mavsp2.html
Looks like the Mach V lower it by 1.25".
-Scott
Old Apr 23, 2010 | 12:30 PM
veggivet's Avatar
veggivet
Be aware that the FSD's won't be available for shipping until May 10th via Tire Rack.
Old Apr 23, 2010 | 01:20 PM
slinger688's Avatar
slinger688
May 10th? Wow, that sale must be pretty popular.
Old Apr 26, 2010 | 02:07 PM
sbarton's Avatar
sbarton
So Koni SA's or Koni FSD's with Mach V lowering springs?
-Scott
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
CooperSharp
Oct 12, 2015 09:21 AM
Suspension Products
Oct 1, 2015 11:53 AM
Suspension Products
Oct 1, 2015 11:14 AM
nshannon29
Sep 30, 2015 05:21 PM
