Pad surface extends over rotor edge
Old Mar 28, 2010 | 09:30 AM
weldon978's Avatar
weldon978
Just put new pads and rotors on my 08 MCS. I put green stuff pads and DBA vented/cross drilled rotors on. I notice that the old pad surface did not extend to the end of the rotor (which causes a small lip to form)... the pad surface on the new pads extend @ 1/4 inch past the rotor edge.
Is this ok?
Old Mar 29, 2010 | 06:57 PM
e30r56's Avatar
e30r56
No it isn't ok. I suspect you have the wrong rotors. Compare new rotor diameter directly to only rotor diameter, should be exactly the same.
Old Mar 29, 2010 | 07:13 PM
ron-s mini's Avatar
ron-s mini
I would check the caliper mounts -- loosen and see if they can be moved in a little. Some over hang is ok and not unusal, but a 1/4" sounds like a lot.
Old Mar 30, 2010 | 06:17 AM
JumpingJackFlash's Avatar
JumpingJackFlash
+1 on checking rotor part number and caliper mounts.
Old Mar 30, 2010 | 06:18 AM
Helix13mini's Avatar
Helix13mini
Yup, Check part numbers, and installation.
molala
Oct 2, 2015 01:53 PM
David.R53
Sep 13, 2015 03:44 PM
marc0011
Sep 10, 2015 10:04 PM
Tires, Wheels & Brakes
Sep 10, 2015 03:10 PM
Sep 4, 2015 09:23 AM
