Question related to Tires
Old Feb 23, 2010 | 03:27 AM
ONEFASTGOKART's Avatar
ONEFASTGOKART
Okay, so I had been driving around for about 30 minutes at speeds of around 40 to 70 mph. At one point I got on the Interstate, just to go to the next Exit. Well after getting off the Exit Ramp, my TPMS Light came on.
The car I have is a 06 MINI JCW GP which has Run Flat Tires and this is the first car I've owned with Run Flat Tires.
I drove the car back home and let it sit for awhile to let the tires cool down. I then checked the Tire Pressure in all 4 tires and found that One tire was down to around 23 PSI. The Tire Pressure is suppose to be at 38 PSI.
My question is, how do I tell if the Tire needs to be replaced OR was it just low Tire Pressure??
Most of the times I deal with just low tire pressure is on very cold days, before I take the car on a Drive. This hasn't happend with the MINI yet though.
Would I need to take my MINI to a dealer or Service Shop and have them look at the tire??
Thanks.
Old Feb 23, 2010 | 03:39 AM
JAB 67's Avatar
JAB 67
Fill the low tire to 38, drive, then check again. If it is low again it needs to be serviced; probably picked up a nail. 'Run Flat' does not mean 'Puncture Proof.'
Old Feb 23, 2010 | 06:13 AM
freez3's Avatar
freez3
From: United States of America, Ohio, Stark County, Uniontown
Right, I'd refill to 38# but also visually inspect the tire. Most of the time if it picked up a nail it'll be visible. If you see a nail DO NOT PULL IT OUT but take your car to have the tire fixed. (If you pull out the nail your slow leak will become a fast leak.) If you find nothing... then monitor that tire for a while to make sure it stays inflated. If it continues to loose air then it needs to be serviced. Often times a tire will loose air for some reason and then not loose it again but you must not ignore it.
Old Feb 23, 2010 | 07:43 AM
ONEFASTGOKART
Well, I don't plan on Ignoring this. I'll keep monitoring the Tire after I fill the low tire up to 38#.
Alkaidovich
Jan 30, 2021 01:35 AM
W0TM8
Dec 19, 2019 07:50 AM
Mini'mon
Aug 16, 2015 04:15 PM
Mini'mon
Aug 16, 2015 12:47 PM
Emnotek
Aug 13, 2015 05:47 PM
