drivers rear tire scraping
Old Feb 12, 2010 | 08:44 PM
bodman's Avatar
bodman
Hi . I changed from run flat tires to standard tires and now have the tire scraping on drivers rear when i go over a bump . other than going back to run flats what can i do to the rear to stop this condition?
Old Feb 13, 2010 | 01:12 AM
howsoonisnow1985's Avatar
howsoonisnow1985
Did you get a 215/45-17 tire? What size?
1st gen or 2nd gen? details.
Old Feb 13, 2010 | 05:25 AM
cmcveay's Avatar
cmcveay
Please post the size of your original tires and the new tires and if you have the OEM mudflaps installed and if the suspension is lowered. If you changed wheels, see if you can get the offset of the new wheels.
I've gone through several tire sizes, mostly non runflats so I can offer some help.
Old Feb 13, 2010 | 07:32 AM
ZippyNH's Avatar
ZippyNH
If the tire diameter stayed the same as the runflats, then you must have a suspension issue. Check the location of the tire, compared to the otherside...is it centered? If the wheel is not properly centered, then it will rub, like you are having, on one side, but not the other. There are a few posts about this issue. Basicly, some suspension parts can be bent out of wack, front to back by potholes, causing this problem, and the car will still handle ok.
If you have a nonstandard/oversized tire, then there are other options as stated above.
Old Feb 13, 2010 | 10:07 AM
bodman's Avatar
bodman
thanks guys I have an 2004 mini, no modifications I had 195/55/r16 run flat, changed to 205/55/r16 . I weigh 275 and figured my fat but has caused the rear spring to sag. Years ago there were spring spreaders. wedge in between spring tighten and it would spread and raise spring a little.
Old Feb 13, 2010 | 10:36 AM
ZippyNH's Avatar
ZippyNH
http://www.miata.net/garage/tirecalc.html
according to this calculator, the new tire is slightly bigger....811 rev per mile, vs 825.... 1.8% so when you speedo says 60, you are going 61.1.
The sidewall height is 2/10th of an inch taller...pretty minimal.
I would take a peek at the shock/strut. make sure it is not failed, then compare the tire centering from to back on the left side,to the right side.
I'm not a tiny gut either, and I don't think that you are overloading it...heck, still lighter than a one avg person in the front, and one in the back!!
Also check out
https://www.northamericanmotoring.co...-question.html
From WayMotorWorks.com
I've had two cars in the shop lately with this same problem. Basicly the trailing arm on each was bent. Not enough you could see it in the arm, just enough you could see the wheel not centered in the wheel well.
Good Luck!!
W0TM8
Dec 19, 2019 07:50 AM
kazyn
Oct 25, 2019 02:34 PM
Minibeagle
Aug 13, 2015 10:00 AM
messyjesse96
Aug 12, 2015 05:51 AM
