Slotted and Cross Drilled rotors?
Old Feb 12, 2010 | 07:24 PM
Justjones's Avatar
Justjones
Can anybody recommend a "good" set of 4 for around $350?
Old Feb 12, 2010 | 08:42 PM
kishg's Avatar
kishg
why not just go with blanks? my experience has been that cross drilled rotors tend to crack. modern pads don't really out-gas so slotted doesn't really have too much benefit either than bling.
Old Feb 12, 2010 | 09:06 PM
Justjones's Avatar
Justjones
haha unfortunately I'm very shallow and they would be for bling, however if what you say is true then $350 for some rotors that will crack is not cool, I'll do some research on that.
Old Feb 12, 2010 | 09:51 PM
maxmini's Avatar
maxmini
Here you go and less than you were looking for at $299. The cracking issue can be a problem which I experienced personally on two occasions with another brand . The main reason for that situation is a lack of proper chamfering or in many cases no chamfering at all. As you will see via the information provided on our site this issue is dealt with properly.
Randy
M7 Tuning
http://www.youtube.com/watch?v=xmDMRSLZqNU
Old Feb 13, 2010 | 01:17 AM
howsoonisnow1985's Avatar
howsoonisnow1985
If you do not track your car (which I extremely doubt) where extreme heavy braking is used, do not worry about rotors cracking.
Old Feb 13, 2010 | 07:52 AM
kishg's Avatar
kishg
it depends. most drilled rotors cause stress risers and the heating/cooling is what cracks them, not really the extreme temp. I've seen them crack under street applications with spirited driving. isn't all mini driving spirited? i would go with the TSW rotors. they are slotted for some bling
Old Feb 13, 2010 | 01:42 PM
maxmini's Avatar
maxmini
I found this to be true as it was the track events that seemed to do them in. I did not have the issue from street driving but it may have been a factor in some small way. The real key was the sharp edges of the holes left over from the drilling process which were excessive heat build up led to the surface crack issue. The company i was dealing with at the time assured me that it was only a cosmetic problem but were nice enough to send me another set anyway. When these also lasted less than season I went back to slotted only.
Randy
M7 Tuning
ericbryant24
55
Sep 30, 2024 02:10 PM
Filmy
15
Jun 6, 2023 06:27 AM
molala
Oct 2, 2015 01:53 PM
Mb460
Sep 14, 2015 05:50 AM
Sep 11, 2015 01:15 PM
