NEW WHEELS MAKING MY BACK TIRES RUB
Old Dec 16, 2009 | 12:56 PM
tcscb1963's Avatar
tcscb1963
I just installed these 17" wheels on my car, and now the back tire rubs a little if I hit a hole. I have 215/45/17 tires and the offset on the rim is 40. I also have H&R Springs installed. Does anyone have any suggestions on preventing the tires from rubbing, besides new tires or stock suspension?
Old Dec 16, 2009 | 01:10 PM
bahawton's Avatar
bahawton
Trim the inside edge of the black arches, fender liner & rear bumper where it makes contact.
Look for wear marks to determine where the rubbing's happening & remove the least possible amount of material. Drive for another week & repeat if necessary.
The only other option is add a lot of negative camber which will cause irregular tire wear & less than ideail traction in the rear.
Old Dec 16, 2009 | 10:02 PM
howsoonisnow1985's Avatar
howsoonisnow1985
+1
That's all you can really do for now.
Are the 17x7 or 17x7.5?
Once the 215/45-17s go bald, try 215/40-17
Old Dec 16, 2009 | 10:33 PM
xnotfunkylex's Avatar
xnotfunkylex
They are really easy to trim. Or if you wait long enough the tired will trim it for you. It won't harm anything though if it's just the plastic.
reverse01134
Jan 16, 2017 06:37 AM
Mini'mon
Aug 16, 2015 04:15 PM
Dashdog
Aug 10, 2015 06:17 AM
nomar116
Aug 9, 2015 09:42 AM
